Post by 190mech on Oct 23, 2016 18:17:10 GMT -5
I'm guessing youve got a 41.? stroke,,the Stage6 seems like its a Mina 39mm stroke casting...
Post by oldgeek on Oct 23, 2016 20:13:54 GMT -5
I'm guessing youve got a 41.? stroke,,the Stage6 seems like its a Mina 39mm stroke casting... From what I can find, I believe you are correct. 41mm
Post by oldgeek on Nov 3, 2016 22:48:20 GMT -5
I recently realized the stock small end bearing was not going to be wide enough for a 70cc kit. I found a wider bearing in my new parts that fit the S6 piston perfect, but was a bit wide for the Athena piston, so I opened up the Athena piston with a file so the wider bearing would also fit. Once again I started checking durations for the two kits and wound up with the Athena cylinder and Athena piston set to EX 193 and xfers 132. Using the S6 head with a 1.3mm head gasket (I gotta fab one up) should get my squish in the range of 1mm as the Athena instructions specifies. This is my first aluminum kit install and 1mm sounds kind of wide to me. Is the squish normally wider on the aluminum kit?
I also still need to document the Yasuni R pipe so 190mech can tell us where its power band will likely be.
Post by niz76 on Nov 3, 2016 23:03:05 GMT -5
Ya I'm interested in that Yasuni R pipe too! I'm wondering if it wouldn't make a great pipe for the Hoca 90cc stuff as the C16 seems to have the power band a tad too high...
Post by 190mech on Nov 4, 2016 5:37:23 GMT -5
Ya I'm interested in that Yasuni R pipe too! I'm wondering if it wouldn't make a great pipe for the Hoca 90cc stuff as the C16 seems to have the power band a tad too high... Niz,Ya oughta try that 40mm spacer in the headpipe we discussed to get the lengths right on the C16 to 103cc before looking for another pipe...
Post by oldgeek on Nov 4, 2016 22:16:20 GMT -5
Post by niz76 on Nov 4, 2016 22:43:17 GMT -5
Ya I'm interested in that Yasuni R pipe too! I'm wondering if it wouldn't make a great pipe for the Hoca 90cc stuff as the C16 seems to have the power band a tad too high... Niz,Ya oughta try that 40mm spacer in the headpipe we discussed to get the lengths right on the C16 to 103cc before looking for another pipe... Was more just thinking out loud about the R, but now more focusing on the 50mm LC MHR Big Bore(s) sitting on my workbench!
Post by niz76 on Nov 4, 2016 22:46:54 GMT -5
Sorry for getting sidetracked Oldgeek! Seems like maybe the extra stroke on your crank could be a blessing in disguise? Seems like I'm usually running into the opposite problem with way too much squish clearance...
Post by oldgeek on Nov 5, 2016 4:54:48 GMT -5
Sorry for getting sidetracked Oldgeek! Seems like maybe the extra stroke on your crank could be a blessing in disguise? Seems like I'm usually running into the opposite problem with way too much squish clearance... Yeah, I know what you mean. I think this is a better problem to have, just make a couple spacers and its fixed. The more I look at this Piaggio motor, the more I like it, no wonder they are so popular mostly everywhere but here.
Post by oldgeek on Nov 5, 2016 22:13:18 GMT -5
Going to premix. Is the pump easy to delete on these?
Post by spaz12 on Nov 5, 2016 22:41:02 GMT -5
It's belt driven and super easy to remove.
Post by gsx600racer on Nov 5, 2016 22:44:04 GMT -5
Going to premix. Is the pump easy to delete on these? I think the pump is belt driven behind the cvt. I think you could just remove the belt and leave the rest hooked up unless you are looking for the few ounces of weight savings. LOL Damn, spaz12 beat me to it.
Post by oldgeek on Nov 6, 2016 5:50:17 GMT -5
It's belt driven and super easy to remove. Going to premix. Is the pump easy to delete on these? I think the pump is belt driven behind the cvt. I think you could just remove the belt and leave the rest hooked up unless you are looking for the few ounces of weight savings. LOL Damn, spaz12 beat me to it. I thought I read somewhere that some type of spacer is needed in place of the sprocket? Maybe not, cant remember.
Post by gsx600racer on Nov 6, 2016 18:34:54 GMT -5
It's belt driven and super easy to remove. I think the pump is belt driven behind the cvt. I think you could just remove the belt and leave the rest hooked up unless you are looking for the few ounces of weight savings. LOL Damn, spaz12 beat me to it. I thought I read somewhere that some type of spacer is needed in place of the sprocket? Maybe not, cant remember. I believe you just remove the belt and leave everything else
Post by oldgeek on Nov 6, 2016 21:16:48 GMT -5
190mech I finally got the pipe dimensions!
