Post by renagade281 on May 28, 2016 19:16:26 GMT -5
OK guys I finally got my hurricane up and running. Now it's time to build it. I have another Scooter that I ride for transportation so I'm gonna be focusing on building this one and taking my time to get good quality parts but I need y'all help because I don't know anything about 2 Stroke parts. I wanna get a nice bore kit for it obviously and what else should I start with?
Post by 90GTVert on May 29, 2016 18:06:14 GMT -5
Post by renagade281 on May 30, 2016 14:49:09 GMT -5
Thanks for that info. I'm thinking a mild sport upgrade right now because I haven't really gotten into changing crankshafts yet. But I can't get the damn thing running again. It's like it starts up then dies. Then it will just turn and turn. If I let it sit for a couple minutes it will start up and then die. I think it has something to do with the filter that's on it. I need to just get a stock airbox for it. I have a straight line going from the tank to the carb with a manual shutoff valve in the middle. The vacuum nipple is capped also
Post by 90GTVert on May 30, 2016 16:32:58 GMT -5
The stock airbox is a good call. That will serve you well even with a sport 70cc. Have yu had the carb off to clean it and inspect it?
Check out autotech355 on eBay. He sells good sport kits at a good price. If you don't want to do it all at once, that should work even with a stock pipe. Will require a little carb and CVT tuning most likely. Then more tuning once you get a pipe. Those iron sport kits are usually able to be adjusted and ported so they can either work with stock or street pipes or more aggressive pipes.
Post by renagade281 on May 30, 2016 21:03:51 GMT -5
i think it already has an aftermarket pipe on it. i will take a pic and post it. and the carb is brand new, when i put the new carb on it fired right up and i drove it about a mile with some sputtering so i figured the open filter was too much with whatever jet came in the carb, so let me order a stock airbox and get back to you
Post by renagade281 on May 30, 2016 21:32:00 GMT -5
It doesn't have any marking on it. The seller said it was an aftermarket pipe. Idk
Post by spaz12 on May 30, 2016 21:33:42 GMT -5
It doesn't have any marking on it. The seller said it was an aftermarket pipe. Idk Uggh! Little tiny pictures
Post by renagade281 on May 30, 2016 21:35:40 GMT -5
click on it lol.
Post by spaz12 on May 30, 2016 21:37:44 GMT -5
Normally I would, but a few days ago my stupid computer stopped letting me click on links and small pictures on this site.
Post by ryan_ott on May 30, 2016 21:38:28 GMT -5
That's not aftermarket it's the stock catalyst pipe. Super heavy and restrictive.
Post by ryan_ott on May 30, 2016 21:43:34 GMT -5
A nice LV ZX would suit you well.
Post by niz76 on May 31, 2016 0:58:50 GMT -5
That's not aftermarket it's the stock catalyst pipe. Super heavy and restrictive. +1
Post by renagade281 on May 31, 2016 5:51:16 GMT -5
Well damn lol
masterofnone
Post by masterofnone on Jun 2, 2016 15:22:54 GMT -5
It doesn't have any marking on it. The seller said it was an aftermarket pipe. Idk It's stock. I have the exact same bike and is high on the list of my many project's. Mine is running atm but if I don't start it for a week or so it takes a while to get it running. I am planning a naked build but who knows. I'm not trying to steal your thread but I think we can compare notes. This is my first 2 stroke build also!
Post by renagade281 on Jun 3, 2016 8:54:34 GMT -5
It doesn't have any marking on it. The seller said it was an aftermarket pipe. Idk It's stock. I have the exact same bike and is high on the list of my many project's. Mine is running atm but if I don't start it for a week or so it takes a while to get it running. I am planning a naked build but who knows. I'm not trying to steal your thread but I think we can compare notes. This is my first 2 stroke build also! No problem. That's cool we are both building our first 2t off the same model. I had to put it off for a bit cause my main Scoot went down and I had to buy a tire... But I found out that a rear wheel from this hurricane will not fit a 4t Scoot. This one has 18 splines and my 4t VIP has 19...
