Post by floyd2133 on Jul 14, 2016 14:19:05 GMT -5
I just recorded what was going on video in next link
Post by floyd2133 on Jul 14, 2016 14:26:06 GMT -5
Post by floyd2133 on Jul 14, 2016 14:27:29 GMT -5
he said he think it's timing. he's checking it now
Post by eclark5483 on Jul 14, 2016 14:56:02 GMT -5
Least he has it running, that's good news.
Post by floyd2133 on Jul 14, 2016 14:59:00 GMT -5
but it won't run without a jump
Post by Deleted on Jul 14, 2016 15:18:07 GMT -5
but it won't run without a jump Won't run without a jump or won't start without a jump? Do you mean he has to keep the jumper cables attached or the engine will quit?
Bill
Post by floyd2133 on Jul 14, 2016 16:45:45 GMT -5
The engine will quit after a min if throttle isn't pressed
Post by floyd2133 on Jul 14, 2016 16:46:21 GMT -5
He's going to replace stator Saturday
Post by Deleted on Jul 14, 2016 18:44:59 GMT -5
The engine will quit after a min if throttle isn't pressed So, instead of tuning the carb's air/fuel screw and setting the idle screw, he is going to replace the stator? This makes no sense. Bill
Post by Deleted on Jul 14, 2016 18:46:11 GMT -5
He's going to replace stator Saturday Did he say why? Did he at least put a meter on the stator and check the output? Did he check it under load? Bill
Post by floyd2133 on Jul 14, 2016 19:13:39 GMT -5
He did tune the idle and mixture screw it still would not start until he jumped it off with the car . So that was his test of the stator. Is there a link to how to check stator
Post by arkie on Jul 14, 2016 19:16:21 GMT -5
Post by arkie on Jul 14, 2016 19:18:24 GMT -5
Have you ever looked for any information here? Its actualy quite easy to find and to learnHow to fix your own scoot.
Post by Deleted on Jul 14, 2016 20:07:27 GMT -5
In case this does not translate well, this means I am standing by waiting to hear what happens next. Bill
Post by floyd2133 on Jul 14, 2016 21:21:07 GMT -5
Have anyone seen the last video? The scooter cranks when jumped by a car but does not have power to jump itself off
