Post by johnhfx on Aug 11, 2016 9:51:46 GMT -5
I just noticed that where the muffler bolts on to the bike is not tightened all the way (looks like a eight of a inch gap on one side) and I can feel air flow from around that area. Is this normal/OK? Does this have anything to do with how loud it is? Again thanks for all your help as I'm totally uneducated on these things. After reading some post I also covered the exhaust hole with my finger at idle and bike did not cut out.. I've read there is some air movement in that area that a small amount of air is normal, and that there is a ring gasket (?) so the small gap probably isn't a big deal? so I plugged the exhaust again and could see the smoke coming from where the pipe meets the silencer (I think that's what it's called, I apologize if I'm wrong). So at that point is that harmful to the bike? Thanks again.
Post by johnhfx on Aug 11, 2016 17:46:58 GMT -5
Took the decals off on one side, went pretty easy. Heat gun and goo b gone and some rags.
Post by Raizer on Aug 12, 2016 6:59:38 GMT -5
It should be sealed between the pipe and silencer. I used a smear of exhaust sealant between them on my pipe.
Post by johnhfx on Aug 13, 2016 19:09:52 GMT -5
Thanks raizer,
I pick some up today and a few small washers, I'm going to take it apart tomorrow and see what I can do.
