Post by 90GTVert on Apr 15, 2011 19:32:52 GMT -5
Project 90
"Project 90" is or is going to be the testing and modification of a 90cc engine. I will be trying to document the tuning and modifications from bone stock and beyond in an attempt to help others that have chosen to swap up to a 90cc Minarelli engine. While the information will hopefully be useful to the 90cc crowd, I hope it will at least be somewhat relevant for the little brother of that engine, the 49cc Minarelli/Jog/1E40QMB. I'm sure I'll forget to document some things I should, and there will be problems here and there as always.
I know I could just bolt on a big bore kit and throw in a stroker crank and get the wildest pipe and so on to take the "easy" route to max performance, but that's not what this is about. This project may never be anything that special in terms of performance, but if those reading this and I can learn from it, I feel it would be a success. Perhaps when I'm done with it, I can condense this thread into a smaller thread with just the facts and figures so to speak, that may prove useful for 2T scooter enthusiasts. We'll have to see how it goes. Those are my basic goals though. I must say, it feels strange to start a build with this sort of goal. I'm more accustomed to shooting for a performance figure.
Let me start the project off by showing you exactly what "Project 90" is starting out as. I picked up this engine cheap on eBay. It is a 49cc Minarelli that has been machined and fitted with a 52mm bore and a 42mm stroke, to make it 89cc just like most engines advertised and sold as 90s.
I went through the engine and discovered that the manner in which it was done would allow me to get it into stock trim. Only the necessary porting had been done, the crank is a stock style crank, and the cylinder is a stock setup. Anything that was not on par with a stock 90cc engine was swapped out for appropriate parts. Stock gaskets and clearances were used to the best of my abilities. The CVT was setup as commonly found stock on 90cc engines as well.
Specifications
(As The Project Begins)
Bore : 52mm
Stroke : 42mm
Note : This shows the travel from BDC to deck as the engine came to me, not the full stroke.
Displacement : 89.2cc
Cranking Compression : 150psi
Squish Clearance : 1.49mm
Note : The stock cylinder head is not a squish band design, as illustrated in the images below. The squish clearance stated is the minimum clearance from piston to head.
Exhaust Duration : 172°
Transfer/Boost Duration : 118°
Carburetor : Stock 49cc/90cc
Note : Most of the Minarelli engines from 49cc to 90cc or so use the same style of carburetors stock. There are some slight variations in styles, and jetting may vary from one scoot to another.
Main Jet : 78
Pilot Jet : Unknown size, stock.
Needle : Stock. Clip in center of 5 positions.
Air Filter : Stock airbox
Intake : Stock
Reed Block and Reeds : Stock
Fuel System : Stock tank, 1/4" hose, 1/4" fuel filter, manual petcock.
Exhaust : Stock 49cc.
Oil Delivery : Pre-mix. I removed the stock oil injection system in favor of pre-mix in order to provide consistent oiling with any modification. I am using AMSOil Sabre Professional 100:1 Premix, mixed at 50:1.
Ignition System : Stock CDI, stock stator/flywheel, Bando coil, NGK BR8HS spark plug. While the coil and plug are not stock, the plug is a stock replacement. The coil should have little to no effect on performance. The only time I've really seen much change with aftermarket coils or spark plugs is on much racier engines, and even then the difference tends to be small. The main benefit tends to be easier starting and more resistance to spark plug fouling.
CVT Belt : 788 17 28 Bando
Roller Weight : 6g
Contra Spring : Stock 90cc
The image below shows a 49cc contra spring (also called a torque spring or main spring) vs a 90cc contra spring. 49cc on the left, 90cc on the right.
Clutch Springs : Stock
Final Drive Ratio : Approximately 10.125:1
Note : I measured the final drive ratio by counting the revolutions of the clutch bell vs one revolution of the rear tire. It rotated roughly 10 1/8 times.
That should cover most of the specs. To sum it up, it's pretty much all stock. The exceptions being pre-mix instead of oil injection, a manual fuel petcock instead of a vacuum fuel petcock, an NGK spark plug, and a Bando ignition coil. I chose the stock carburetor setup from a typical 49cc Chinese scooter as well as the stock exhaust from a Chinese 49cc scooter, because I have had many people ask me if it's O.K. to use these components on a 90cc engine.
This engine has been installed in my stripped down Triton, that most of us here know as T2. The lack of fairings allows for much easier access for repair and adjustments, which is an incredible benefit for this particular project.
Other Info For Reference
Elevation : ~40ft Above Sea Level
Rider Weight : 260lbs
Fuel : 91-93 Octane (Premium)
I have more info to share, but I'm going to take a little break from typing and uploading. I may go out and gather more data? ;D
Specifications
Bore : 52mm
Stroke : 42mm
Main Jet : 78
Intake : Stock
Roller Weight : 6g
