Post by Scootrific on Apr 20, 2017 9:18:06 GMT -5
Oh, . I think I´m getting old and my brain does format C or restart - sometimes. Tnx, 90GTVert .
Post by Scootrific on Apr 21, 2017 12:31:35 GMT -5
Today I made a mistake and took a ride with rain . Scoot died few times and scoot was cutting power, but I got home. After that there was smoke near the cylinder head. The scoot started once, after sitting one hour, then did not start at all. I took off the air filter, that I last installed and connected the original airbox to carb. Tomorrow I will clean the original air filter box and carb with carb cleaner and try again. Maybe that will fix the problem.
Post by Deleted on Apr 21, 2017 12:50:58 GMT -5
CDI got wet? I had the same problem, scooter dying. Had to move CDI to another location.
Post by Scootrific on Apr 22, 2017 3:00:54 GMT -5
CDI got wet? I had the same problem, scooter dying. Had to move CDI to another location. I will check that out too
Post by Scootrific on Apr 22, 2017 5:07:17 GMT -5
Well, the scoot did not start today at all. I cranked the motor over so many times, that the battery got flat. I went to nearby automotive shop and brought Benton BX-4 Battery charger (6V and 12V moto/car). I had the same charger, when I had my last scoot:
Post by 90GTVert on Apr 22, 2017 6:36:50 GMT -5
Check for spark.
Post by Scootrific on Apr 22, 2017 7:00:33 GMT -5
When the battery gets fully charged, then I will check the spark and spark plug. Maybe it need cleaning.
Right now I´m rendering the RideAlong ScootVlog Part 5 video. I did put the rainy weather clips to that vlog. It will come out soon.
Post by Scootrific on Apr 22, 2017 10:21:43 GMT -5
Well, 90GTVert! I took the spark plug out and cleaned it. Before cleaning, it looked like this: I took a video too, before my scoot´s battery died again:
Post by Scootrific on Apr 22, 2017 11:10:10 GMT -5
Before I brought the Benton BX-4 Battery Charger, I placed order from Star Moto Estonia: Starter 50cc - GY6,139QMB QMA Rear bottom left plastic Rear bottom right plastic Under tail light small plastic Battery ytx5l-bs-mf Battery charger TecMATE Optimate 1: TecMATE Optimate 1: INFO: Detail 24/7 Safe long term battery care. Maintain any type 12 volt lead-acid battery without overcharging, filler cap / wet cell, sealed AGM (MF) or GEL. Ideal for vehicles that are seldom or seasonally used, or in storage. CHARGING AMPS : 0.9A * (tapered current) * European model delivers 0.6A USE : Indoor (lowest temperature: -4°F / -20°C). SAVE : Low Volt Start of 8V IDEAL FOR : STD, AGM & GEL 12V batteries from 2-50Ah INPUT : North America (TM85) : 110-120V 50-60Hz Europe (TM88) : 220-230V 50-60Hz STYLE : Plug-in case (vented), with 12ft / 370cm charge lead ending in SAE connector. weatherproof battery lead & small battery clip set included. SAFE: No risk of overcharging. Totally safe for vehicle electronics. Sparks suppressed. Safe for long-term battery maintenance. Thermally protected. Automatic shut-down if short-circuited or battery disconnected. 3-year limited replacement warranty.
Post by 90GTVert on Apr 22, 2017 11:14:11 GMT -5
But does it have spark?
Post by Scootrific on Apr 22, 2017 11:34:52 GMT -5
I did not check for spark, but the Trailtech Tach/hour meter showed rpm´s between 900 and 1000.
Post by Scootrific on Apr 22, 2017 11:54:37 GMT -5
Hey, 90GTVert Here is the RideAlong ScootVlog#5, that has the rainy ride videos and the scoot problems, while riding. Time stamps are in the description too. Scoot problems are starting: 10:45 Scoot problem 1 - Dies: 11:30 Scoot problem 2 Power loss: 12:00 Scoot problem 3 Dies again: 13:05 E
Post by hamsun on Apr 22, 2017 14:52:32 GMT -5
Heya. This sparkplug is dead...! You must replace it for new one... Cleaning is no make it better...D!In our weather you must have with you about 1-2 sparkplugs... Video is good!
Post by Scootrific on Apr 23, 2017 3:50:12 GMT -5
Today I swaped the old spark plug to a brand new one, tested the spark with both of them. The video is with the new spark plug. The scoot did not start, after swaping the spark plug. Tach showed 1000rpm. Scoot wanted to start, but did´nt.
Post by 90GTVert on Apr 23, 2017 5:17:56 GMT -5
Alright, now try different throttle positions when starting. Try restricting airflow (covering the airbox inlet) or allowing more (removing the airbox) to see if that gets it. Try adding a few drops of gas in the cylinder or even spraying carb cleaner through the carb or an unlit propane torch in the airbox inlet so it has some fuel for sure and then see if it starts.
