Post by pinkscoot on Nov 9, 2016 15:37:42 GMT -5
I'll be interested in how it works for you and what your durations are. They should be the same but you never know. I'm trying to decide on a pipe for it, Scoot-tuning has the Next R for $79 or Racing planet has the Yasuni R for $268. I'm not sure if the Yasuni is worth $200 more. Anyone have experience with each?
Post by Jwhood on Nov 9, 2016 15:46:21 GMT -5
Yeah I'm looking at the yasuni r for my corsa cylinder on my tgb, I'm not sure if that malossi would run at the rpm a yasuni r runs good at!!!
Post by ThomasTPFL on Nov 9, 2016 17:27:44 GMT -5
We've already got a Leo Vinci ZX on the bike, so we'll see how it does with that.
Post by pinkscoot on Nov 10, 2016 17:19:13 GMT -5
Jwhood the best I see right now is about 8500, I was seeing 9200 with the Multivar so I'll probably replace the bad one. I'm waiting for some money before I do anything. Maybe I'll get the Flywheel for my TGB and will see what the Next R does on that.
Post by Jwhood on Nov 10, 2016 19:54:02 GMT -5
What stator you have the 8 pole or 4 pole,and you running the red tip cdi or the green tip cdi or an unrestricted cdi?
Post by pinkscoot on Nov 11, 2016 13:23:21 GMT -5
On my TGB? Its an 8 pole stator with I think the Red CDI. Its been a while since I looked at that scoot, I'm waiting for the Flywheel that goes with the 8 pole stator.
Post by Jwhood on Nov 11, 2016 14:42:45 GMT -5
I think I have an extra 8 pole flywheel
Post by pinkscoot on Nov 11, 2016 14:45:47 GMT -5
Its already coming from Taiwan. I just emailed TGB USA to see when I can expect to see it. If its to much longer I might be interested in yours.
Post by pinkscoot on Nov 15, 2016 16:17:00 GMT -5
I pulled the exhaust off of my parts bike and started cleaning it up. This is a picture of it: . After searching I discovered it is a Metrakit SP Exhaust. Of course if I had started here I would have found it right away, this forum has all of the information you need. I think I'll put it on and see how it works before I clean it up. I'll also do some more research on it. Does anyone have any experience with this pipe?
Post by Lucass2T on Nov 16, 2016 1:35:09 GMT -5
Im not sure if thats a metrakit sp. I have one too, lemme look for some pics to compare!
Post by tsimi on Nov 16, 2016 4:15:06 GMT -5
I thought you can't use a center stand with the Metrakit SP pipe.
Post by spaz12 on Nov 16, 2016 5:35:23 GMT -5
The stinger on an SP mounts to the belly of the pipe, so I don't think that's an SP
Post by tsimi on Nov 16, 2016 5:56:52 GMT -5
Post by Lucass2T on Nov 16, 2016 7:51:10 GMT -5
I thought you can't use a center stand with the Metrakit SP pipe. True! But only with minarellis.
Post by pinkscoot on Nov 16, 2016 11:30:55 GMT -5
I went ahead and cleaned it up and painted it. The paint does not want to come off the silencer. I have some off and can see its a black Kevlar. I'll get some measurements tonight so I can see if its the Metrakit. Looking at the dimensions from Lucass it may be close, I'll try it anyway.
