Post by thxcuz on Aug 30, 2016 22:17:52 GMT -5
i got a new head the other day. I installed it today and the scooter does not run. It's a 47mm head. it was the only one the guy had at the scooter shop. I have a 47mm kit on my scoot so I thought it would be fine. I needed a new head due to a stripped stud hole
at first it wouldn't start, then it started but it would not idle, then i got it to idle but i had no power. I was going maybe 3 mph. then I adjusted the valves again. I found the bolt on the exhaust rocker came off. I guess I didn't tighten it enough. after that it ran ok up and down the alley. When I tried to start it again, it would not start. checked my valves again, they were around .004, where they should be, right? I have spark because I was able to start it here and there. do you think I am not getting fuel? I have noticed that spacer thing on my intake was not lined up with the hole on my new head, could that be restricting the fuel?
Post by Deleted on Aug 31, 2016 3:12:28 GMT -5
what does a compression test show?
Post by thxcuz on Aug 31, 2016 8:49:58 GMT -5
I don't have a tester yet. If I'm not mistaken they can be rented from auto zone.
Post by humanshield on Aug 31, 2016 9:10:45 GMT -5
Many of the kits don't have the proper size adapter for scooter spark plugs. I know this one does.... Compression Test Kit
Post by 90GTVert on Aug 31, 2016 11:03:53 GMT -5
If you want to find out if the tester has the right adapter for you, the 139QMB uses 10mm spark plug threads. Autozone has loaner tools as well as others.
Post by acvw74 on Aug 31, 2016 16:22:39 GMT -5
Post by thxcuz on Aug 31, 2016 17:32:50 GMT -5
I'm not ruling anything out. I'll test it for a leak tonight.
Post by acvw74 on Aug 31, 2016 20:18:05 GMT -5
I'm not ruling anything out. I'll test it for a leak tonight. I just always try to eliminate the easy stuff first. Good Luck!!
Post by thxcuz on Sept 1, 2016 0:10:10 GMT -5
my finger test shows not a lot of compression. I know that's not accurate but it's all I got so far. I think I may also have messed up my starter or wore out my starter bendix. a guy at one of the local scooter shops has an atm50 taking up room in his shop. it may be worth the $100 he wants for it just for parts.
Post by 50chinkschinkin on Sept 2, 2016 16:58:07 GMT -5
Check valve lash and that the valves are seated properly
Post by kagetenshi on Sept 2, 2016 20:54:09 GMT -5
thxcuz I would buy that atm-50. Even if it doesn't run, it is worth more than that in scrap metal much less parts. Hell, the atm-50 frame is better than the VIP I have. It might possibly weigh more but it can take more of a beating. Though I may be wrong. You could piece it out on eBay and make more than double if you tried. So it is worth the $100 for parts. I say do it.
Post by humanshield on Sept 2, 2016 21:31:22 GMT -5
When your garage starts to look like this....you'll almost have enough spare parts scooters on hand
Post by thxcuz on Sept 2, 2016 21:45:09 GMT -5
Can I come over and play at YOUR house?
Post by Deleted on Sept 2, 2016 21:47:47 GMT -5
I started with one, I now have three, one running, one rebuilding, one just sittin and I'm trying to figure out what to offer a guy for 150...
Post by humanshield on Sept 2, 2016 21:53:29 GMT -5
I've gotten rid of 4 so far this year.....the old lady gave me an ultimatum
