Post by oldgeek on May 29, 2017 14:11:43 GMT -5
Not much room on the short case rear for a 12" wheel that will not be much bigger than what you already have.
Post by AtariGuy on May 29, 2017 15:01:47 GMT -5
Not much room on the short case rear for a 12" wheel that will not be much bigger than what you already have. then i have an excuse for a new engine build! Maybe go 50?
Post by AtariGuy on Jun 6, 2017 19:09:40 GMT -5
I'm talking with a buddy of mine, an experienced welder by trade, and we're looking at going a custom bobber route with the frame in the coming weeks. Currently planning it all out and trying to find a gas tank to use. Will keep updated as things start taking shape!
Post by AtariGuy on Jun 7, 2017 22:01:34 GMT -5
Theoretical idea, can i do a final chain/belt drive from the rear output axle to a fixed wheel? Like atv/gokart?
Post by 190mech on Jun 8, 2017 3:28:37 GMT -5
Yep,there was a Derbi done like that a while back,the GP1...
Post by AtariGuy on Jun 15, 2017 23:29:36 GMT -5
So i'm finding i blow through a tank of gas in 30 miles. Is this typical of a 2T? I believe my tank holds about 1.3-1.4 gallons...
Post by spaz12 on Jun 16, 2017 0:54:04 GMT -5
I get more than that with my scoot.
Post by ryan_ott on Jun 16, 2017 11:29:13 GMT -5
You should get more then 30 per tank, 30 per gallon would be better. Are you filling up at the pump or a gas can? If from a can maybe your putting less in then you think you are.
Post by AtariGuy on Jun 16, 2017 11:55:23 GMT -5
I'm filling at the pump. My routes are all gps'd for distance and logged as of now as my stock speedo/odo doesnt work, but my routes show roughly 30-40 miles on an average 1.3 gallon fill/mix
Post by 90GTVert on Jun 18, 2017 6:46:05 GMT -5
I'm at 35MPG most of the time with T2's 103cc/21mm PHBG. It's been that way with many engines. I can get 50MPG, but I have to ride slower. Check tire pressures when fuel consumption is high and make sure you aren't seeing any leaks. Could be a rich tune.
Post by aeroxbud on Jun 18, 2017 7:05:23 GMT -5
I think even with the stage 6 racing and c16 I was getting roughly 40-45 mpg
Post by benji on Jun 18, 2017 10:21:23 GMT -5
Could also be the way you ride 😈 I'm constantly running the piss out of my scooter. Full throttle everywhere, revving constantly like a teenager. I'm sure that may have an effect on mpg.
Post by AtariGuy on Jun 18, 2017 11:47:13 GMT -5
True point. I'm sure my mpg will get better when i start having throttle to spare while cruising too
Post by oldgeek on Jun 18, 2017 13:31:32 GMT -5
Theoretical idea, can i do a final chain/belt drive from the rear output axle to a fixed wheel? Like atv/gokart? You certainly can! Look on ebay for the parts from a predator ATV's or similar. I have a set somewhere around I am saving for a project.
Post by benji on Jun 19, 2017 13:06:09 GMT -5
Are there any minarelli- based trikes out there? I've seen a few 150cc 3- wheel scooters, maybe the rear end from one of those would work.
