Post by tsimi on Nov 6, 2017 9:17:08 GMT -5
I just got an update on my Roost order. The kit will be restocked in 3 weeks. Need to be patient.
Post by PIG on Nov 6, 2017 14:11:26 GMT -5
Do already have a carb for this build? If not I’ll be selling my Keihin 28mm if your interested.
Post by spaz12 on Nov 6, 2017 14:56:13 GMT -5
I hope you'll be putting that all to good use soon!
Post by 190mech on Nov 6, 2017 14:59:08 GMT -5
How bout reed selection?Whatever you choose may require some special fitment/case grinding,etc.Oughta have them there before the cases are bolted together..
Post by tsimi on Nov 6, 2017 16:52:14 GMT -5
PIGThanks for the offer but I have a Keihin 28mm already for this build. 190mechI was thinking to go for the Malossi VL14 reed block. I think that one won't require any case modifications.
Post by tsimi on Nov 7, 2017 6:50:38 GMT -5
Second package arrived. Thanks ryan_ott for all the extra stickers and block off cover. Stuff was very well packed, you even protected the TD threads from getting damaged, thank you. The TD is HUGE! Lot bigger then I imagined. Curious, what are the 3 large, black bolts for? And which was the famous needle that fixes the low-/mid-range area? JJH? Man look at all those needle and jets.
Post by ryan_ott on Nov 7, 2017 12:34:34 GMT -5
Glad it made it there safely. Those bolts are the thread for the Aerox hub. I couldn’t remember if you had them or not and I had extras.
JJH is usually the go-to Needle.
Post by PIG on Nov 7, 2017 14:58:54 GMT -5
Glad it made it there safely. Those bolts are the thread for the Aerox hub. I couldn’t remember if you had them or not and I had extras. JJH is usually the go-to Needle. Why did you sell your overrange Ryan?
Post by ryan_ott on Nov 7, 2017 16:53:32 GMT -5
Glad it made it there safely. Those bolts are the thread for the Aerox hub. I couldn’t remember if you had them or not and I had extras. JJH is usually the go-to Needle. Why did you sell your overrange Ryan? To fund toys for my truck. Also for my area it’s overkill, I managed 60 out of the stock parts so I think that’s good enough.
Post by tsimi on Nov 8, 2017 1:38:59 GMT -5
Does anyone know is the kick start assembly for an Aerox engine (Minarelli long) the same as for the Jog engine (Minarelli short) ?
Post by spaz12 on Nov 8, 2017 15:45:40 GMT -5
Not sure about the Jog, but for sure the Zuma assembly stuffs right in there. I'll try to get you some pics this evening if you haven't already figured it out.
Post by tsimi on Nov 8, 2017 16:34:15 GMT -5
That would be great, thanks.
Post by tsimi on Nov 9, 2017 17:00:59 GMT -5
Does anyone know the OD for both radiator nipples on a LC cylinder?
Post by 90GTVert on Nov 9, 2017 17:15:45 GMT -5
I suppose it could vary by kit, but likely around 17mm.
Post by tsimi on Nov 9, 2017 18:31:34 GMT -5
Thanks Brent. I didn't know that this might vary depend on cylinder. Then I'll better wait till I get my LC kit first before ordering radiator hoses.
