Post by Lucass2T on Mar 24, 2018 3:05:33 GMT -5
Tsimi, have you read Graham Bell's book? If not, buy it. You'll love it!
Post by tsimi on Mar 24, 2018 3:27:15 GMT -5
Tsimi, have you read Graham Bell's book? If not, buy it. You'll love it! No I haven't. I am not good at reading books. Always falling asleep after 1-2 pages. Is there a movie? I am a modern era human we don't read anymore.
Post by tsimi on Mar 24, 2018 3:30:33 GMT -5
Interesting to see is the cylinder skirt is lot thicker similar looking to a 50cc. I guess for better stability and heat resistance?
Post by Lucass2T on Mar 24, 2018 5:28:13 GMT -5
Interesting to see is the cylinder skirt is lot thicker similar looking to a 50cc. I guess for better stability and heat resistance? Yep! Take a look at the TM KZ10 cylinder skirt tho.
Post by tsimi on Mar 25, 2018 0:39:24 GMT -5
A lot of meat has to go.
Post by Corrosion on Mar 25, 2018 10:07:18 GMT -5
Better put the circlips in right! That piston could slip out the export port undetected.
Post by PIG on Mar 25, 2018 12:42:00 GMT -5
So where are the progress pics? Chop chop we’re all waiting
Post by tsimi on Mar 26, 2018 1:33:17 GMT -5
LoL, no pressure please. I need one scooter to get to work, daily. Therefore I have to time everything since I am about to swap the front and wheels on my Prebug. Roadmap:- Prep the Aerox engine to fit the cylinder, crank, setup Iggy and OR CVT stuff.
- At the same time strip apart the whole front of the Prebug and swap in the Aerox fork, naked handle bar and Aerox wheels and convert to front disc setup.
- Once that Prebug is done I can start to strip apart the Jog and figure out how to mount the radiators and what needs to be cut away on the plastics.
- And then I can start to mount the Roost engine and try to fire her up.
Post by PIG on Mar 28, 2018 23:05:41 GMT -5
Post by tsimi on Mar 28, 2018 23:15:09 GMT -5
Patience, patience.
I don't have a garage so everything has to be done in house. I can't grind around late time, wife wouldn't like that. I will try to get the cases done during weekend. I also need to get some wheel painting done aswell.
Any one know of some 10 inch tires that have a higher speed rating than J ?
Post by tsimi on Mar 28, 2018 23:32:35 GMT -5
PIGAny last advice regarding grinding?
Post by Lucass2T on Mar 29, 2018 2:05:26 GMT -5
Patience, patience. I don't have a garage so everything has to be done in house. I can't grind around late time, wife wouldn't like that. I will try to get the cases done during weekend. I also need to get some wheel painting done aswell. Any one know of some 10 inch tires that have a higher speed rating than J ? Continental Contitwist. They're M rating (130kph).
Post by tsimi on Mar 29, 2018 5:54:16 GMT -5
Did a quick test grinding to see how it feels. The engine material/meat is harder than I thought it would be. I think I should be able to get it done without issues. Oh and yes...."chips are flying!" ...or something similar right?
Post by PIG on Mar 29, 2018 10:25:02 GMT -5
Post by pitobread on Mar 29, 2018 11:49:43 GMT -5
Tape off the areas you dont want to grind... that way if the dremel skips you wont be super sad!
