Post by 90GTVert on Aug 7, 2012 15:50:43 GMT -5
I was gonna skip out on doing a port map for my 47mm from Autotech355, then I realized that the other 2 in this thread are different from mine and each other. :stars: Not sure what time frame this was from. I've had it for at least 6 months and the seller bought it from Autotech355 some time before that before using it briefly and deciding to resell.
Post by bradswims11 on Aug 9, 2012 17:45:36 GMT -5
This is my aluminium nikasil port maps from Carlos at autotech355. 47mm big bore with a single piston ring cylinder
Post by bradswims11 on Aug 9, 2012 17:50:19 GMT -5
Just a photo of it too minus one port
Post by jmkjr72 on Aug 9, 2012 18:46:03 GMT -5
hoca hm lc 53mm bore
Post by oldgeek on Sept 20, 2012 19:42:52 GMT -5
Stage6 Street Race 70cc cast iron
Post by 90GTVert on Oct 30, 2012 15:37:46 GMT -5
A couple of maps for horizontal minarelli AC thanks to teddy554... Here is a port map of the stage 6 iron street race 70cc kit and some photos of both kits Stage6 MKII Alr
Post by JEGZ on Dec 21, 2013 1:24:03 GMT -5
sport pro 22.5mm barrel clearance to achieve 11,000rpm powerband with ruima 41.4 stroker. stock cylinder hits at about 10,000rpm. works well with pro pipe.
Post by vlatx on Jun 18, 2014 10:22:47 GMT -5
Taiwanise 47mm 12mm 1E40qma kit,standard ports
Post by vlatx on Jun 18, 2014 11:38:02 GMT -5
And this is the portmap i want to make to the Taiwanise 47mm kit.
Post by vlatx on Mar 27, 2015 8:34:56 GMT -5
Chinese 47mm 12mm 1E40qma kit,standard ports
Post by Jwhood on Apr 6, 2015 6:43:29 GMT -5
Malossi liquid lc 319747# 10mm wristpin bbk 47mm.....[
Post by mauibird on Apr 25, 2015 6:37:24 GMT -5
Autotech355 54mm Aluminum Bore (77mm/short)
Post by 90GTVert on May 9, 2015 13:25:28 GMT -5
Post by ryan_ott on Jul 2, 2015 20:48:45 GMT -5
This is from the booklet that came with the kit. It only shows 1/2 the ports, 9 total. Malossi "77" 50mm bore, 39.2 stroke 196/130.5
Post by Corrosion on Dec 28, 2015 15:10:33 GMT -5
For those interested in the Port Map of the. Stage6 R/T 70cc MK I PN-S6-7516602
