kglazer
Post by kglazer on May 30, 2011 15:49:24 GMT -5
ok ill go with the 1000 contra and 2000 rpm clutch now i just need to find a tuning kit that comes with heavier roller weights I'm thinking 7-10 grams because i have 6 grams now and with those upgrades i need to go heavier where can i find those wights in a tuning kit.
Post by Thebatman on May 30, 2011 19:18:13 GMT -5
Several places..... Provoscooter.com...ebay...vtcycles.com...Scooterassassins.com
kglazer
Post by kglazer on May 30, 2011 19:38:23 GMT -5
yeah i checked but cant seem to find them in a kit of tuning ones
kglazer
Post by kglazer on May 30, 2011 19:44:16 GMT -5
i found a polini roller kit with 6.6gram, 7.6gram, 8.5gram, 9.1gram roller weights. is polini a good brand and do you think these will be the right sizes if im running 6.5 now and its stopping at 30 with the 1000 contra and 2000 clutch spring. or should i get even heavier ones?
kglazer
Post by kglazer on May 31, 2011 12:49:43 GMT -5
also how can i tune my carburetor i know there are screws but idk what they are called or where they are and what they do a diagram and explanation would be great as i think the carb could be a issue of it topping out at 30mph
kglazer
Post by kglazer on Jun 1, 2011 17:17:33 GMT -5
are there any local stores that carry jets for my carb?
Post by warriorboxerdog on Feb 8, 2012 23:17:01 GMT -5
Ok I have a super 8 ac. Im thinking it the same as the super9 ac cuz a lot of the parts fit. The first thing I did was upgrade the variator with the kit from molossi. It came with the variator 9 gram roller weights and a sport torque spring. I installed it all go more take off more top end. Next I replaced the carb with a arreche 19mm carb and a manual choke. It inproved the performance more. I could get 40mph out of it. Stock restricted speed was 25 to 28mph. Next I eant with the technigas next r (the one for (50cc) I noticed a major change with this take of was better, power for climbing hills was better and top speed was 45+ Since I have upped the main jet to a 70 which was good with the stock air cleaner, Now Im running a 75 lowered the clip on the needle jet and run a open air cleaner, I also tried dr pully sliders and went with 9 grams which caused me to loose some power. I got 10 gram dr pully on the way as well as sport clutch springs by mo;pssi to match the torque spring and a 80 nain jet. Remember my scooter is very heavy around 230lbs and has 14inch tires. Im hoping to be able to hit 50 or more in less time it used to take. I will post my results on here when Im done the mods Im waiting for.
Post by warriorboxerdog on Feb 8, 2012 23:20:19 GMT -5
Oh just some friendly advise dont mess with scootertronics. I ordered from them when I first got my scoot and they suck! they have a million bad reviews on the internet! I learned the hard way but not as hard as others have. Just look and you will fing the horror storys!
Post by 90GTVert on Feb 9, 2012 10:59:31 GMT -5
:welcome: warrior. There are some stories in our review area about Scootertronics. I assume they must get much less business these days, because most of the scooter community that posts on forums seems to stay clear these days.
