Post by eclark5483 on Mar 4, 2017 14:25:57 GMT -5
Oh, that be nasty!!! You need a new tank dude. You can get one direct from TaoTao's distributor here in the US. www.eagleatvparts.com/Probably run ya about 50 bucks plus shipping.
Post by eclark5483 on Mar 4, 2017 14:39:20 GMT -5
BTW, post a pic of your scooter so we can identify the exact model for you.
Post by pinkscoot on Mar 5, 2017 11:14:51 GMT -5
Maybe the PO thought clay was a good way to fight ethanol or they thought they could grow corn in the gas tank.
Post by sn1per01 on Mar 7, 2017 9:32:26 GMT -5
I have purchased a new tank, filter, and petcock, the scooter is an ATM50-A1.
Post by roadrunner420 on Mar 8, 2017 20:22:32 GMT -5
Its definitely the float,I had the same thing happen while riding! Luckily I had my tool kit with me and was at a gas station,I emptied my carb took it off opened it up and blam!! The float was stuck open .after reassembly it never happened again and mind u this was a brand new kiehin 20mm performance carb..idk go figure, hope you guys get it fix bro #SCOOTERLIFE.
Post by Senna1Rossi on Mar 10, 2017 11:39:49 GMT -5
Welcome
Post by sn1per01 on Mar 16, 2017 15:45:43 GMT -5
Ok, so the new tank didnt work, will try the float now.
Post by sn1per01 on Mar 16, 2017 16:00:39 GMT -5
Though I would like to point out that this is happening with 2 carbs, what are the chances that both have stuck floats?
Post by sn1per01 on Mar 16, 2017 16:55:29 GMT -5
Actually, can fuel with sediment or something cause the float to jam?
Post by sn1per01 on Mar 19, 2017 18:11:47 GMT -5
So, I was testing the bike and put it to full throttle and it was about to die when a screw fell out of the bottom of the carb, once that happened, a bunch of fuel came out but it ran perfectly...
Post by eclark5483 on Mar 19, 2017 18:32:20 GMT -5
Air/Fuel mix screw? If so, you're running way to rich.
Post by 90GTVert on Mar 20, 2017 6:05:01 GMT -5
Fuel with debris in it could cause float issues and other problems. If you haven't already, the carb should be cleaned after replacing the tank and fuel lines to be sure not of that crud is still in the carb.
If fuel continued to pour out, maybe you lost the float bowl drain screw or a screw that secures the float bowl and having less fuel in the carb allowed it to run better? You'd need to inspect the carb and figure out exactly which screw is missing.
Post by sn1per01 on Mar 23, 2017 8:15:28 GMT -5
the thing is that it was as lean as possible, and the screw that fell out was in fact the drain screw. I plan to take apart the carb and I found a scooter club in my area and someone was willing to help.
Post by sn1per01 on Apr 7, 2017 15:11:23 GMT -5
Post by 90GTVert on Apr 7, 2017 19:32:31 GMT -5
That helped a lot! I'm gonna bet it's your lack of air filter. When you hit the gas and I heard it, I was certain it was running out of fuel or very lean. Then I saw the airbox and that sealed the deal for me. Here's a quick clip of my ATM50 when I just removed a "restriction" in the airbox and tried it. I still had the lid and filter in place. youtu.be/K5j8gHg5kMc?t=6m42s
