Post by geoffh on Mar 28, 2021 8:18:05 GMT -5
That's totally different to my slider, and BWS. They must of changed the design at some point. I guess that's why some have two springs. And some one. Every days a school day. Paul all my jogs have been the same set up ,ignore my two springs comment (ravings of a mad man) Geoff
Post by geoffh on Mar 28, 2021 8:22:59 GMT -5
On the plus side my foggy clock problem has dissapeared, I like to think the small bag of dessicant silica gel I squeezed in the housing is keeping moisture at bay.
Post by geoffh on Apr 2, 2021 8:19:12 GMT -5
The accelerator cable gave up while it was on warm up at work,it was snapped right near the twist grip end,the logistics are complex but I returned last night with a replacement cable but failing light and a fancy coupling I couldn't,t fathom and then I pulled the carb end up into the nut which jammed in there .After much twiddling and WD40 the cable is now free and the fancy coupling now fathomed I can fix the scoot Saturday am. Geoff Quick update scoot fixed and back to normal,the repair was easy.
Post by geoffh on May 1, 2021 8:06:36 GMT -5
My centre stand and more to the point the housing for it has needed replacing for a long time now. I have been over thinking the job for quite sometime the whole scoot was resting on the exhaust pipe so I have addressed the problem by fitting a side side. It cost £30 from pedparts UK,ordered Tues del Fri so hats off to the supply chain.it,s made in Italy by RMS and I am very pleased with the quality and fitment, here it is it,s very model specific and so no drilling adjusting plates to bother with,it comes with the shortest fitting instructions I have ever seen just a picture and one sentence ,does the job though.
Post by geoffh on May 1, 2021 8:47:55 GMT -5
Back in June 2020 I was a bit rude to Naraku because of the early exhaust failure,shame on me,the centre stand broke the exhaust,sorry about that.
Post by captincvmn on May 1, 2021 9:01:37 GMT -5
I quite like my Keeway side stand. It’s no good for service but it’s very good for holding my bike upright. (It’s only fallen once and that’s because I had it leaning uphill which actually made it straight up and down)
Post by aeroxbud on May 1, 2021 9:15:25 GMT -5
The simplest ideas are often the best. I did think about fitting a side stand on the slider. It's very easy to fit. Yamaha even Mark out the hole to cut in the panel for you. But no, I decided to drill the broken steel stand out of the aluminium casing. what a pain in the butt job.
Post by geoffh on May 7, 2021 15:38:23 GMT -5
The journey home was fun, it cut out while I was overtaking 30 or so cagers sat at the lights so I pushed it to safe spot and used my travelling tool kit to investigate,spark and fuel lines OK so I stripped the carb and found the pilot jet loose in the bottom of the bowl,put it back together,it did not want to start but after a few kicks I tried at half throttle at it fired up,rode the last 4 miles no problems.I am just swapping out for a new coil but beer o'clock came round so I will update later. Geoff
Post by aeroxbud on May 7, 2021 15:44:36 GMT -5
Lucky you had tools on you. It's good it's lighter at night now as well.
Post by 190mech on May 7, 2021 16:57:52 GMT -5
Darn!That scoot must have a lot of power to vibrate the pilot jet completely out!!
Post by geoffh on May 8, 2021 8:28:53 GMT -5
Darn!That scoot must have a lot of power to vibrate the pilot jet completely out!! It,s not the power,much more likely that I did not tighten it up after chasing the poor start problem. Geoff
Post by geoffh on May 8, 2021 8:44:49 GMT -5
So I noticed the spark was a bit weak almost orange so I have put a new coil on,visual difference at the plug strong blue spark now. I left it a few hours to go cold and it kicks up easily now just like the old days,fingers crossed my poor start condition has left. The coil must have been failing/fading out but it,s 17 years old and now and retired I will keep it for garage art. Geoff
Post by aeroxbud on May 8, 2021 9:01:23 GMT -5
It's a constant job keeping these old scooters on the road.
This week someone a couple of streets up brought home a red jog RR, like I used to have. It's been sitting in their front garden with the seat bucket out. I'm guessing it's a none runner. Looks like it's been under water. Very poor condition. There are still old jogs out there.
Post by geoffh on May 8, 2021 9:38:40 GMT -5
I might have to rename the scoot,triggers brush is up there.
Post by geoffh on May 9, 2021 8:44:24 GMT -5
Well I feel like I got a new scoot I let it sit all night and it fired up first kick,the butt dyno shows much better acceleration and it feels peppy again,because I ride every day I don't,t realise the performance had dropped off and I thought the ignition coil would be good or bad not as in this case tired but still functioning,lesson learned.
