Post by paceneedsstides on Apr 30, 2017 14:26:14 GMT -5
Post by paceneedsstides on Apr 30, 2017 14:32:07 GMT -5
Post by paceneedsstides on Apr 30, 2017 14:37:24 GMT -5
Now for the sad news. . . . almost ready to start assembly and timing and Joe found a crack in the case. . . .it was hidden well under JB weld and a glob of grease and he says it was definitely hidden on purpose and a dick move. THIS IS NOT I REPEAT NOT Brandons doing which is who I got the case from and he had already contacted who he got it from and another half case was already on it's way before they even contacted me. So not that I planned on having this done anytime soon anyway but gonna be a bit longer now. . . .
Post by ryan_ott on Apr 30, 2017 17:18:50 GMT -5
Not to sound like an a hole but I quick degrease would of revealed that prior to putting time into the cases. Lesson learned I suppose.
Post by moofus02 on Apr 30, 2017 17:51:57 GMT -5
That bites
Post by paceneedsstides on Apr 30, 2017 20:31:19 GMT -5
Not to sound like an a hole but I quick degrease would of revealed that prior to putting time into the cases. Lesson learned I suppose. My guess is since Joe does so much work for Brandon there was never any doubt as to wether the case was sound or not but it's being taken care of funny thing is I had mentioned a couple days before I thought I saw a crack turned out it was a casting mark but Joe told me I must be lucky and should buy a lottery ticket. . . .
Post by Lucass2T on May 1, 2017 1:16:03 GMT -5
That cylinder looks super clean. Im sure it will flow well!
Post by paceneedsstides on May 1, 2017 12:56:39 GMT -5
That cylinder looks super clean. Im sure it will flow well! yeah he did a lil work on the kit while waiting for putty to cure he has more work to put into it.
Post by paceneedsstides on May 9, 2017 23:34:40 GMT -5
Post by tsimi on May 10, 2017 0:10:58 GMT -5
What is that grey color thing that he put on after porting? You can see it good in the last picture the case on the bottom.
Post by paceneedsstides on May 10, 2017 0:29:20 GMT -5
What is that grey color thing that he put on after porting? You can see it good in the last picture the case on the bottom. it seems to me if you go back in the pics where it first shows up it's just some type of media blasting or polishing
Post by tsimi on May 10, 2017 0:33:08 GMT -5
So he is cleaning the cases after porting with some sort of blaster? Looked like some sort of special paint to make the surface slightly rough.
Whatever it is it does look good. Too bad you won't see it anymore once the engine is assembled.
Post by paceneedsstides on May 10, 2017 0:40:03 GMT -5
I will ask him tomorrow and get an answer I assumed it was bead blasting to get the junk off when ready to seat the bearings and assemble but can't be sure so will let you know when I get an answer from him
