Post by ryan_ott on Jun 5, 2017 20:38:33 GMT -5
Wow your right it has only been a month. Maybe I'm ahead of schedule then.
Post by gsx600racer on Jun 5, 2017 20:44:49 GMT -5
Wow your right it has only been a month. Maybe I'm ahead of schedule then. LOL, I went to the beginning of the thread to check.
Post by ryan_ott on Jun 7, 2017 16:47:18 GMT -5
I think this will be money well spent...
Post by spaz12 on Jun 7, 2017 16:49:27 GMT -5
I use mine all the time.
Post by tsimi on Jun 7, 2017 18:28:07 GMT -5
And I would love to have one.
Post by ryan_ott on Jun 9, 2017 16:34:19 GMT -5
I'm just going to leave this here... A little persuasion and it fits.
Post by PIG on Jun 9, 2017 17:36:15 GMT -5
How much does it interfere with the pipe?
Post by ryan_ott on Jun 9, 2017 18:18:52 GMT -5
How much does it interfere with the pipe? Like this: Not one bit. The torsen is far enough inward that it's a good fit.
Post by tsimi on Jun 9, 2017 18:22:45 GMT -5
So the torsen acts as supporter and bracket for the pipe. Nice! What did you modify to make it fit?
Post by PIG on Jun 9, 2017 18:22:46 GMT -5
Looks hot af!
How you liking the Zuma so far?
Post by ryan_ott on Jun 9, 2017 18:40:43 GMT -5
So the torsen acts as supporter and bracket for the pipe. Nice! What did you modify to make it fit? They are meant to work with Polini pipes but I don't see why the won't work with others. You may need to make a bracket. I had to cut the original exhaust mount off the case. I removed about 20mm. Drill and retap the original mounting holes and stand back and look at it. I think I might need to paint it a darker grey, it's too light for me.
Post by ryan_ott on Jun 9, 2017 18:43:19 GMT -5
Looks hot af! How you liking the Zuma so far? Thanks man! I am really enjoying it. There is a difference once the bigger wheels went on, like heavier steering. I love it. I should of got one sooner.
Post by gsx600racer on Jun 9, 2017 21:46:03 GMT -5
How much does it interfere with the pipe? Like this: Not one bit. The torsen is far enough inward that it's a good fit. Looks awesome Like it was meant to be.
Post by spaz12 on Jun 9, 2017 23:40:17 GMT -5
That's a nice cut on the case half Did you use a portable band saw?
Post by spaz12 on Jun 9, 2017 23:43:30 GMT -5
So the torsen acts as supporter and bracket for the pipe. Nice! What did you modify to make it fit? You wouldn't need to cut that to fit it on your Aerox motor because that exhaust bracket/case half is shorter. You would most likely need to make a bracket for your pipe though.
