Post by ryan_ott on May 23, 2017 18:40:14 GMT -5
Today I got everything together enough to take it for a 4 mile lap. Besides what I think might be spark knock at part throttle, let's just hope it's not the crank crying, it seems pretty good the first time out. I'm running 4.2 grams and a soft Polini blue spring, clutch springs could be tighter they are tHe HiT black ones, I'm currently at 45/110 w7 and 40 slide max temp was 275. I don't have a tach on it yet but I know the RPM's are high.
Post by oldgeek on May 23, 2017 18:51:48 GMT -5
Airbox or pod?
Post by spaz12 on May 23, 2017 19:18:16 GMT -5
Sounds like a pod filter to me.
Myself, I'd go with a heavier contra spring. The ol trusty malossi yellow is my fav unless I'm dealing with a messed up TD and that's when I use the lighter spring. But that's just me.
Post by ryan_ott on May 23, 2017 19:31:31 GMT -5
Post by ryan_ott on May 23, 2017 19:33:25 GMT -5
Sounds like a pod filter to me. Myself, I'd go with a heavier contra spring. The ol trusty malossi yellow is my fav unless I'm dealing with a messed up TD and that's when I use the lighter spring. But that's just me. I need to get a tach on here to see where I'm at. I'll experiment with springs. Once it's moving it feels good for what it is. I'm just concerned with what rpm's I'm turning.
Post by aeroxbud on May 23, 2017 19:54:34 GMT -5
It was going good for a first ride 😀
Post by ryan_ott on May 23, 2017 20:31:44 GMT -5
I stole a tach off of another bike so I'm ready for tomorrow's testing. I might go with heavier rollers, we'll see. Here's my fancy kill switch and quick throttle, more of a on-off throttle.
Post by spaz12 on May 23, 2017 20:33:26 GMT -5
Nice throttle.
Post by ryan_ott on May 23, 2017 20:36:14 GMT -5
Thanks, it was a pain getting my cable length perfect but well worth it in the end. I so hate a sloppy throttle where there's too much slack.
Post by PIG on May 23, 2017 20:50:06 GMT -5
That polini pipe makes good power, I really liked my on the prebug. Really similar to the C16 for power delivery, rpm etc.
Post by ryan_ott on May 23, 2017 20:59:30 GMT -5
True PIG It just keeps pulling. Hopefully I'll get this dialed in by the weekend, motor that is. I've got wheels and suspension to continue on.
Post by oldgeek on May 23, 2017 21:44:39 GMT -5
You may want to consider a W6 (richer) needle to go with the pod. It sounds good now though.
Post by aeroxbud on May 24, 2017 9:54:21 GMT -5
That's a nice set-up on the throttle and kill switch.
Post by ryan_ott on May 24, 2017 18:38:46 GMT -5
How do you think that little 10mm pin is going to like:
Post by ryan_ott on May 24, 2017 18:41:03 GMT -5
You may want to consider a W6 (richer) needle to go with the pod. It sounds good now though. I tried a W6 2nd notch from the top, way too rich 225 max temp. I only had full throttle or idle. You should of seen my neighbors. I'm going to try the W7 richer.
