Post by ryan_ott on May 17, 2017 11:51:01 GMT -5
Post by joshua864 on May 17, 2017 12:22:14 GMT -5
I'm running 120/70/13 front 130/60/13 rear
Post by ryan_ott on May 18, 2017 20:08:59 GMT -5
I'm just trying to pick away at this when I get some free time. Working on the carb today to get a decent tune, I was having issues getting it to pull any rpm then I realized I read the jet wrong I had a 86 in but I thought it was a 98. I grabbed a quick video of it reving out on a stand. I don't have a tach on it yet but I'm kind of impressed, not that it is the stock 10mm pin crank though I think I'll be changing that soon. I have all the switches to start swapping the bars which I'm thinking I'll be doing sooner the later so I have all the gauges I want in it without cluttering up the stock cluster. I just need to work out what I need for the stem and clamp.
Post by ryan_ott on May 21, 2017 20:08:00 GMT -5
After a ridiculous amount of yard work today I got some time to get my controls wired up correctly so I can retain key function and a proper kill switch. Followed by removing all the electric start parts so I can make room for an overrange. I'm going to start out with 4.2gr and see where that gets me. Anyone else have issues fitting a HiT clutch bell with an overrange, there's not many threads to catch onto. I'm thinking I'm going to need a tach on here... Here is my easy peasy way to swap clutch springs, instead of using your bench vise I just use a lag and washer right into my work bench. It's not going anywhere. Out with the old In with the new Clutch secured
Post by ryan_ott on May 21, 2017 20:44:00 GMT -5
I think I just made a discovery... I got a Polini wd Torsen arm for a clone that didn't fit so it's been collecting dust here. I did some quick measurements and I think it'll work on here. Yay me! I'll pull he exhaust tomorrow and confirm.
Post by spaz12 on May 21, 2017 20:48:31 GMT -5
Pig is running a HiT clutch with the Malossi OR. If you notice that your TD isn't opening all the way I have some more of those TD/Clutch shims. That'd be hella cool if that Torsen bar fit
Post by ryan_ott on May 21, 2017 20:56:23 GMT -5
The clutch fits fine it's the bell. I'll look into it tomorrow I've had a long day as it is. I'm really hoping the Torsen fits! The adapter fits the axle threads and the length looks correct. Tomorrow...
Post by tsimi on May 21, 2017 22:02:14 GMT -5
Looks and sounds great! I didn't follow your thread but what I could catch thus far.
Polini pipe Malossi OR HIT clutch 21 dello
BBK? AC? LC?
Post by PIG on May 21, 2017 22:11:21 GMT -5
Pig is running a HiT clutch with the Malossi OR. If you notice that your TD isn't opening all the way I have some more of those TD/Clutch shims. That'd be hella cool if that Torsen bar fit If you have an extra TD shim I'll buy it off you. Save me the time of making one
Post by spaz12 on May 21, 2017 22:24:07 GMT -5
Pig is running a HiT clutch with the Malossi OR. If you notice that your TD isn't opening all the way I have some more of those TD/Clutch shims. That'd be hella cool if that Torsen bar fit If you have an extra TD shim I'll buy it off you. Save me the time of making one I do. I have two .3mm and two .5mm shims. I think those are the widths. So which ever ya need.
Post by moofus02 on May 22, 2017 1:16:56 GMT -5
I think I just made a discovery... I got a Polini wd Torsen arm for a clone that didn't fit so it's been collecting dust here. I did some quick measurements and I think it'll work on here. Yay me! I'll pull he exhaust tomorrow and confirm. That arm is for the aerox cases. The Zuma and adly cases are the same length but the Zuma cases are wider at the pipe mount (adly also probably)than the aerox. Someone is running one on a Zuma but they had to trim the cases some to make it fit.
Post by ryan_ott on May 22, 2017 5:22:07 GMT -5
Looks and sounds great! I didn't follow your thread but what I could catch thus far. Polini pipe Malossi OR HIT clutch 21 dello BBK? AC? LC? There is a Polini cast 70 kit that came with the bike I put on it. AC for now, I have plans for going LC probably once I kill this crank. When that happens I'm really leaning towards the metrakit prorace 3.
Post by ryan_ott on May 22, 2017 17:38:26 GMT -5
I think I just made a discovery... I got a Polini wd Torsen arm for a clone that didn't fit so it's been collecting dust here. I did some quick measurements and I think it'll work on here. Yay me! I'll pull he exhaust tomorrow and confirm. That arm is for the aerox cases. The Zuma and adly cases are the same length but the Zuma cases are wider at the pipe mount (adly also probably)than the aerox. Someone is running one on a Zuma but they had to trim the cases some to make it fit. Turns out your right. The exhaust mount sticks out 3/8"-1/2" too far. It could be cut but the motor would need to come out for that. Back to the shelf...
Post by tsimi on May 22, 2017 17:46:15 GMT -5
It is for an Aerox engine right? Don't want to sell it? spaz12 ? I would love to get one for my Aerox engine but I am far from driving ready.
Post by moofus02 on May 22, 2017 18:00:07 GMT -5
Corrosion I think runs one. He trimmed the case a little and the arm a little to make it work
