Post by Delpzie on Sept 1, 2018 14:55:16 GMT -5
I installed the clutch put 3gr rollers and went on short test, but i only got 2minutes to try it cuz i live in 3rd world country u know people are stupid here 98% in this country, 4people instatly came and said its shame to drive like that so "fast" i understand the scooter is bit loud but they are just no words i dont know what to say. Tomorrow i will try it from what i saw in the dark rpms were 14200rpm it rips but i think its just little much i might need in between rollers 3,2-3,3gr. Also no problems on start now the clutch on full throttle the scooter starts going 9000rpm something like that bit more no boging rips right from the start.
Baotian
Sept 3, 2018 11:48:10 GMT -5
Post by Delpzie on Sept 3, 2018 11:48:10 GMT -5
Okey so with the new clutch little lighter rollers the scooter is going crazy. I started to warm it up it came to 53degrees i stopped turned on ulysse speedometer full throttle it did wheelie rps were 13 640 after second 14 460 then 14 800 then in like half second scooter stopped like the clutch disengaged and then continued to 14 960rpm and i let off gas, all this happend in around 100-120meters speed on the gps was 84 haha. Also the carb idk whats with it now even with the 38pilot jet starts leaking from the bottom and keep in mind that even this pilot jet is big if u go lower pilot jet 32 it still leaks and u cant even set rpm with that one either 4000rpm or the scooter doesnt work it shuts down. With this pilot jet idle is fine 2500 i give it gas a little it stays around 4000 after 3-4sec drops to 2500 kinda weird i will have much more work in this scooter then i thought so hah, for start i will be putting 4gr rollers those are the heaviest i have. Here is video u can see it overrevs www.youtube.com/watch?v=qstzd-GCEiI
Baotian
Sept 5, 2018 12:54:20 GMT -5
Post by Delpzie on Sept 5, 2018 12:54:20 GMT -5
Guys what do u say about 16-40 gearing ? Its 37,50% more than my original rightnow i think its little overkill maybe not ?
Baotian
Sept 8, 2018 16:19:20 GMT -5
Post by Delpzie on Sept 8, 2018 16:19:20 GMT -5
Today i did tests with the 3,5 rollers and i lost hope with this current gears for sure i cant tune the scooter it just has way too much power i must buy longer gearing. From start is slow cuz 2seconds it holds 13 100 after 1sec it starts overrevving cuz the belt instalty comes to max position and upwards from 13,500rpm the scooter starts flying. To be able to tune it properly to hold constant 13 800-14k rpm is impossible with stock gears. www.youtube.com/watch?v=8WtykHja0xQ
Baotian
Sept 29, 2018 15:11:47 GMT -5
Post by Delpzie on Sept 29, 2018 15:11:47 GMT -5
Few things happend in the past days , first the clutch bolts gone off, i used glue and put it back with glue, changed the torque drive angle and put the disk on the innerotor. With the disk the rpms are lot more stable feels nicer overall, also i got suprised how much it does wheelie this picture is nothing standard little gas goes up, once i wanted to see what will happen if i hold wot like 1 sec and the scooter just started going up up and up if i didnt let go the throttle i was gonna flip it scared the crap out of me. In general i just need to buy 13-43 gears and the gear cover and im good to go will do that this winter for this season thats it. I will drive it little more how much the weather lets and then it goes in garage till spring, the scooter just has too much power not driveable i dont like it like this but it is what it is.
Post by Delpzie on Nov 10, 2018 18:11:20 GMT -5
Today i did some longer driving , drove 50km carb is perfectly tunned, the scooter rips here is my best try yet to start the scooter from 0 its impossible www.youtube.com/watch?v=Z2ruL2b2Sck
Post by niz76 on Nov 11, 2018 12:05:26 GMT -5
Too Much Power!?? NEVER!
Post by Delpzie on Dec 11, 2018 15:42:52 GMT -5
Post by Delpzie on Feb 8, 2019 12:10:48 GMT -5
Baotian
Apr 14, 2019 18:33:11 GMT -5
Post by Delpzie on Apr 14, 2019 18:33:11 GMT -5
Today was first day scooter got out of garage after last season, carb tune is from last season im little rich on pilot jet other than that fine.Here is some videos from todays riding. www.youtube.com/watch?v=YYfAaQ2JNOAwww.youtube.com/watch?v=cW23XmpoRXoAlso im thinking about building 100cc 2Fast cylinder,crank and exhaust but i dont have idea how would i be able to drive it on the streets it has insane power, im not sure if its doable.
Post by Delpzie on Apr 14, 2019 18:35:27 GMT -5
Baotian
Apr 16, 2019 15:21:53 GMT -5
Post by Delpzie on Apr 16, 2019 15:21:53 GMT -5
Also i forgot to mention i did some things before this, i drilled the plastics so i have much better flow and lower temperatures. I also changed the oil in the front shocks and over did it its very stiff now i need to drain some of it. Installed this hose for the oil in the transimssion now its closed loop. I also made new holders for the front plastics cuz they broke because of the wheelies the scooter does.
Post by Delpzie on Apr 16, 2019 15:33:03 GMT -5
I will be adding 3rd bearing support like on piaggio/china scooters, this is example from the polini cases that they sell, i will be ordering the special polini nut and then rollerbearing.
Post by Delpzie on Jul 5, 2019 7:53:23 GMT -5
Gears are here , Top Racing 14-42/13 which are 25% longer, i decided for them because i dont want power wheelies i just wanna launch instantly from the start. Also got some octane booster will be putting all together these days hopefully, its very hot outside like 35C its impossible to do anything.
Also i forgot to mention that i got new EGT Display and its working great cant wait to see that too.
Baotian
Sept 26, 2019 11:03:25 GMT -5
Post by Delpzie on Sept 26, 2019 11:03:25 GMT -5
