Post by Delpzie on Sept 26, 2019 11:56:50 GMT -5
Baotian
Sept 29, 2019 14:48:05 GMT -5
Post by Delpzie on Sept 29, 2019 14:48:05 GMT -5
Today i did carb and transmission adjusting, i just need 0.1gr heavier weights or i might not need, tomorrow i will put the rotor plate from the selettra it will add weight on the crank probably will be perfect, now im revving 14 110rpm on full throttle it rips. I recorded few videos with track addict i was testing it, it was so scary to drive with one hand. Here is the video, watch out for the wind noise put volume lower www.youtube.com/watch?v=VyAk_-NLFgk
Baotian
Nov 20, 2019 12:04:11 GMT -5
Post by Delpzie on Nov 20, 2019 12:04:11 GMT -5
Sum-azn-kid
Baotian
Jan 17, 2020 23:04:40 GMT -5
via mobile
Post by Sum-azn-kid on Jan 17, 2020 23:04:40 GMT -5
Did you really have to grind that much of the case to clear the OR kit? And what brand kit did you use?
Baotian
Feb 25, 2020 19:37:56 GMT -5
Post by Delpzie on Feb 25, 2020 19:37:56 GMT -5
Did you really have to grind that much of the case to clear the OR kit? And what brand kit did you use? You have to grind quite a lot but i overdid it a bit just to be sure not wanna think that i will rip my belt at 15k rpm, i use the malossi mhr overrange kit.
Baotian
May 9, 2020 18:10:39 GMT -5
Post by Delpzie on May 9, 2020 18:10:39 GMT -5
So i got KOSO RX2N GP Speedometer and did some tuning and other stuff this season, today i did topspeed try but i run out of road, the scooter was still pulling hard at 133, i got 133km/h @14,600rpm today, i need to find longer road and push it max, when i go full throttle its kinda crazy i cant even hold my hands at the handlebars, it rips. www.youtube.com/watch?v=rDZVNjwqhFo
Post by Zino on May 9, 2020 18:23:51 GMT -5
Wow That is amazing Its like a rocket. Who needs a 80 miles per gallon When you can get 80 miles per hour
Baotian
May 11, 2020 9:23:14 GMT -5
Post by aeroxbud on May 11, 2020 9:23:14 GMT -5
That really flies up to 80kph. Sounds great too.
Baotian
May 11, 2020 13:02:44 GMT -5
Post by Delpzie on May 11, 2020 13:02:44 GMT -5
I think the rollers can be little more heavy so i drop like 100-150rpm but still it rips like crazy, also need to loose the clutch a little bit more kinda grips too high at 12-13k somewhere, or i need to find much stronger clutch spring but there isnt harder than the malossi red in my country, gonna need to order from scooter-attack. Edit: Here is how it runs with 3,478gr www.youtube.com/watch?v=LIHd6eJjgVU
Baotian
Jul 4, 2020 17:57:38 GMT -5
Post by Delpzie on Jul 4, 2020 17:57:38 GMT -5
Here is some fresh footage from today, riding this beast around town, it was too hot outside so i was runing rich everywhere, i dont have time to tune the carb, but still okey just slower 1sec to 100km/h, and runing 14k rpm instead of 14,300 where it destroys. www.youtube.com/watch?v=a3rlf3LG9yw
Post by Delpzie on Jan 10, 2021 16:16:26 GMT -5
This was last ride from 2020 and top speed of 135km/h, with a bad spark plug and the belt busted, still i run out of road and there was wind against me, it can do 140km/h im sure but season ended and i sold my Malossi Overrange. www.youtube.com/watch?v=_u3d7gWFmG0
Post by Delpzie on Jan 10, 2021 16:18:02 GMT -5
Post by aeroxbud on Jan 10, 2021 17:54:59 GMT -5
That looked pretty quick. Should be a monster with the 100cc.
pewpew
Post by pewpew on Jan 10, 2021 18:03:08 GMT -5
Im sure you are going to love that cylinder, i got the same one on my aerox with a 44mm crank.
Post by Delpzie on Jan 10, 2021 21:41:21 GMT -5
Yea i think the 100cc will destroy idk how im gonna keep it on the ground, my 70cc was so insane too im gonna miss it for sure, im thinking of putting it on my other daily scooter, its literally faster than most 70-86cc`s i`ve watched on youtube, i saw a zuma 86cc bidalot kit my 70cc was way faster then it, idk if the guy is from this forum.
Anyway i ordered the bidalot crankshaft 48/95 for it they dont have it im waiting on it, also i got full mxs racing intake, polini hyper evolution 2 12.5degree racing variator, evolution 3 ventilar 12.5 degree aswell, those parts arrived at my friend in germany, now waiting for crankshaft, also waiting on my KRM 100cc exhaust to arrive, next is calipers, discs, adapters, brembo rcs 19 corsa corta cylinders, 38mm airstriker and a lot of other custom stuff i have to do. I will be posting as stuff comes, also i wanna do vlogs builidng it.
