Post by paydem on Jan 26, 2018 16:10:40 GMT -5
Damn. Looks real good with Aerox wheels. If I only had the money for them lol, could buy them now but saving up for a new variator.
Post by benji on Jan 26, 2018 19:39:06 GMT -5
Thanx. Look for mbk nitro wheels, almost the same. Actually my front wheel is from a nitro.
If your getting a variator, save for a malossi overrange. Best variator available for minarelli. My kit cost $225 or so and it was a good deal. Totally worth it, besides losing the electric starter.
I got it put together and the brakes bled, new exhaust gasket and pipe bolted on. Fired it up, but it needs some carb work still. My float needs adjustment. Almost there tho. Im tempted to just ditch this mikuni and get a new oko or something.
Post by ryan_ott on Jan 26, 2018 19:55:45 GMT -5
*cough* Dellorto *cough*
Post by benji on Jan 27, 2018 21:58:54 GMT -5
Got the mikuni working and not leaking or overflowing. Now I gotta adjust the OR. I took it for a ride today and she was hitting like 11k, so I'm pretty sure I'm gonna need to order rollers n maybe a torque spring. I'm using the 3.8g rollers that came with it, I think I'm gonna order some 4.5g and see if it brings it closer to 8k or so during acceleration.
Post by benji on Jan 27, 2018 22:22:07 GMT -5
I can't afford that fancy Italian shit! Haha. Only used dirt bike parts for me haha.
Post by benji on Jan 28, 2018 0:20:27 GMT -5
Added about 6 grams of Tin foil to my 3.5g set. Total weight is 28g.
Post by birdman on Jan 28, 2018 12:28:48 GMT -5
Nice work. Just caught up on this thread and now I'm subscribed
Post by benji on Jan 28, 2018 14:46:26 GMT -5
The tin foil helped but it still needs more weight I think. I'm gonna order some 5g rollers and hope that'll do it. Also haven't got this damn mikuni fixed, it just pours gas out itself. I'm gonna pick up a new carb and new clutch and some rollers this week and hopefully ill be done with it and can start riding.
Post by benji on Jan 29, 2018 2:14:31 GMT -5
Ordered a new 21mm oko from a forum-er, as well as some led bulbs and 4.75g s6 rollers. They're not as heavy as I wanted but they were crazy cheap and I figure I can stuff tinfoil in them and make them work.
Post by ryan_ott on Jan 29, 2018 20:35:12 GMT -5
On your next parts order get some of the Stage6 tuning rollers. You can mix and match until you find the best weight. They are very long lasting and have replacement shells. They run about $23.
Post by benji on Jan 29, 2018 23:47:18 GMT -5
I can't seem to find that roller tuning kit in stock anywhere for 19x15.5. oh well. I'll have to fine tune using tinfoil I guess haha.
Post by benji on Jan 31, 2018 22:56:25 GMT -5
Got my led bulbs today. Here's the brakes on.
Post by benji on Jan 31, 2018 23:04:04 GMT -5
Also got a carb from eclark, a 24mm pwk w a cable n foam filter. Did some filter tuning w tape Put a little tape around it to help w jetting (hopefully)
Post by lilpinny on Feb 1, 2018 9:23:44 GMT -5
I gotta catch up on this thread. I haven't seen the tape on the UNI before... if anything I've seen the reverse... run it with the second foam layer off (the red portion). Interesting!
Post by moofus02 on Feb 1, 2018 10:22:45 GMT -5
I gotta catch up on this thread. I haven't seen the tape on the UNI before... if anything I've seen the reverse... run it with the second foam layer off (the red portion). Interesting! The tape adds some restriction kinda like an air box. Helps make the tuning more consistent with weather changes but still not as stable as air box
