Post by benji on Feb 15, 2018 12:45:30 GMT -5
Ordered a jjh needle and 35 keihin pilot jet last night.
Post by benji on Feb 18, 2018 12:20:00 GMT -5
More scoot porn. I've been riding it alot lately, even tho it's cold and it's running a little rich.
Post by benji on Feb 21, 2018 0:51:51 GMT -5
Post by benji on Feb 21, 2018 22:34:33 GMT -5
got my jet and my needle today. They also sent me some stickers, 2 small ones and one big one ("10x"4).
Post by tsimi on Feb 22, 2018 21:16:54 GMT -5
Did you use the Zuma spindle/bolt to mount the wheel or did you get an Aerox one?
Post by benji on Mar 19, 2018 21:33:22 GMT -5
Hey Tsimi sorry I didn't see this. I used the zuma hardware (axle n spacer) along with the zuma fork, only problem was the caliper/rotor alignment. I had to space the caliper towards the wheel and find a 180mm rotor to replace the 190mm oem aerox rotor since the zuma uses a smaller setup.
Currently running a 35pj, 92mj, jjh needle middle clip.
Post by benji on Apr 16, 2018 12:28:41 GMT -5
Tried to go to an 88, didn't like it. I went back the 92mj, and I put some more tape around the foam unifilter. Cleaned up the lower range a bit. A may try a bigger pilot w smaller main.
Post by benji on Apr 22, 2018 15:38:47 GMT -5
New aerox fender mounted! Had to trim it to get it to fit. Used zipties to mount it.
Post by moofus02 on Apr 22, 2018 15:49:46 GMT -5
New aerox fender mounted! Had to trim it to get it to fit. Used zipties to mount it. Thought you had Aerox forks on that. Them and the stage 6 forks have mounts for that fender. You should just send it to me lol
Post by moofus02 on Apr 22, 2018 15:50:09 GMT -5
Looks good
Post by benji on Apr 22, 2018 16:11:00 GMT -5
I do have an aerox fork that does fit this fender but not this bike haha. Kind of a shame I had to cut it, but it's not noticable I think. I actually found these online for around $50 or so if anybody wants to get one lemme know I'll post a link.
Post by moofus02 on Apr 22, 2018 17:30:37 GMT -5
Yes please. Your tubes on this bike 30mm or 27?
Post by tsimi on Apr 22, 2018 18:14:17 GMT -5
benjiCurious, how did you handle the original wiring when you swapped to naked handle style? Did you cut and rewire? Or did all the plugs fit down below? Any chance of getting close up pics of the handle bar and the stem where the wiring is?
Post by benji on May 8, 2018 8:46:47 GMT -5
Tsimi I'll a pic of the bars so you can see. I just stuffed the harness down lower and rewired the stuff i was gonna use (brake lights and kill switch). Here's a pic of my new yellow 3k hids
Post by benji on May 8, 2018 8:53:37 GMT -5
