Post by benji on Feb 1, 2018 23:45:40 GMT -5
Basically replace that black rubber thingy with washers and red bushings. I think.
Post by Tanuki on Feb 2, 2018 1:47:34 GMT -5
I see how that would work, but then its not really lowered.
Post by Happypancake! on Feb 2, 2018 6:16:50 GMT -5
TAke off the nut. Remove the black rubber thing. From the bushing kit. , add a washer then 2 bushings a washer nut then yoke. Install.
Post by jbjhillbilly on Feb 2, 2018 12:03:08 GMT -5
Post by Tanuki on Feb 3, 2018 0:47:36 GMT -5
Ok ok ok. I GET it. Thanks guys. Did I ever mention my mechanical ignorance? Its vast
Post by Tanuki on Feb 3, 2018 20:10:44 GMT -5
Post by lilpinny on Feb 3, 2018 20:21:25 GMT -5
Sweet!
Post by Happypancake! on Feb 3, 2018 20:27:41 GMT -5
There you go!
Post by benji on Feb 3, 2018 23:52:10 GMT -5
Looks good to me!
Post by Tanuki on Feb 4, 2018 2:41:20 GMT -5
Chopped 2&1/2"s off the fork springs.
Post by Tanuki on Feb 4, 2018 2:46:36 GMT -5
My totalruckus.com secret santa gifts are starting to come in. I got the worlds largest thong. The guys in my club think i can wear them like overalls. Might just put em on and blast around the block on my minibike.
Post by Tanuki on Feb 8, 2018 1:27:00 GMT -5
Forks could still use an 1" off i think. Got the juices flowing and she fired up, I ate smoke for real. Need some rattler can action on the fucked plastics. Has anyone used glow in the dark paint? Saw it at ace. Sprectoplasm!
Post by Tanuki on Feb 10, 2018 2:33:09 GMT -5
I dont think oil injector works, what i thought was oil movement is probably gas going down the tube. Went to research on spreenet and FUCK NO! Its gone like totalruckus So i guess ill start premixing. Want the front lower still. Anybody ride a bike with NO suspension?
Post by benji on Feb 10, 2018 9:25:41 GMT -5
I do! Or have before, and the zuma is hard tail and just barely sprung up front. I also hardtailed my spree-a-relli, and it wasn't bad. I just pulled the springs out the fork and replaced the rear shock with a peice of metal scrap. Handling will be like a drag bike- awesome going straight, mind those corners and bumps tho. Especially corners w bumps Also, I've gotta extra spree motor w oil pump that may work.
Post by 90GTVert on Feb 10, 2018 9:46:26 GMT -5
I've rode midbikes that went 35-60MPH with square steel tubing in place of their rear shocks and minimal front suspensions and did not find them pleasant for real world use. Fun for parking lots and never bothered me there, but lots of bumpy back roads made me buy shocks for anything not staying in parking lots. The suspension doesn't just keep us comfortable, but helps to keep the tires in contact with the road.
