Post by hppowdercoating on Dec 18, 2017 11:26:04 GMT -5
2005 Metro Engine :Honda AF16 2T 72cc Ported Polini Corsa 44.4 Mini stroker Crank polini Clutch $ Bell Daytona Variator stage6 Riser CT black intake stage6 V force reed block stage6 26mm RT carb 7:51 gears Arrow Pipe progress so Far: Made & installed Custom Engine mount. Custom Rear Pegs/Mounts Under Seat Gas Tank Relocation custom Naked Bar setup with Trailtech Vapor mount.. ![](https://s20.postimg.org/f74t662s9/image.jpg) ![](https://s20.postimg.org/71mr80m95/image.jpg)
![](https://s20.postimg.org/q6q0hs8mx/image.jpg) ![](https://s20.postimg.org/fwnlijqh5/image.jpg) ![](https://s20.postimg.org/ncmv4clw9/image.jpg) working on on installing custom wiring harness & new Led Turn signals in front & Rear..
Post by gsx600racer on Dec 18, 2017 11:41:26 GMT -5
Looks sweet. Funny, most take the MET front ends and put them on the Elites, you did the opposite, Nice work.
Which brand mini stroke crank did you use ?
Did you do the porting to the corsa ?
Post by hppowdercoating on Dec 18, 2017 11:53:19 GMT -5
Looks sweet. Which brand mini stroke crank did you use ? Did you do the porting to the corsa ? Crank is a 2ab Crank No I did not do the Port work. Joe from MVS did port work..
Post by aeroxbud on Dec 18, 2017 15:31:51 GMT -5
Looks like it could be a nice build. 😀
Post by jbjhillbilly on Dec 18, 2017 20:14:49 GMT -5
Would love to see more detailed pic of the naked bar setup.
Post by spaz12 on Dec 18, 2017 21:12:14 GMT -5
Post by pitobread on Dec 19, 2017 15:34:58 GMT -5
Hey do you have the part number for the S6 reed block that works in the CT intake? Perhaps a photo?
Post by hppowdercoating on Dec 19, 2017 17:23:56 GMT -5
Hey do you have the part number for the S6 reed block that works in the CT intake? Perhaps a photo? Don't have a part Number, bought it that way. Here's a Pic..sorry not great pic.. ![](https://s20.postimg.org/k6ksxhs2h/image.jpg)
Post by ryan_ott on Dec 19, 2017 18:39:54 GMT -5
Looks like it’s meant to be there. Well done.
Post by Raizer on Dec 25, 2017 7:31:02 GMT -5
Post by hppowdercoating on Dec 25, 2017 14:06:50 GMT -5
Mount pics... I will have Mount Kits for sale after First of the Year... Message me if interested.. ![](https://s20.postimg.org/ehamod7ft/image.jpg)
![](https://s20.postimg.org/x9mhrxw49/image.jpg)
Post by benji on Dec 25, 2017 16:04:26 GMT -5
Why did you relocate the gas tank under the seat?
Post by pitobread on Dec 25, 2017 16:16:27 GMT -5
GET Motor would have used electric lift pump, probably easier.
But he could have used a Dio pulse pump.
Post by hppowdercoating on Dec 25, 2017 20:10:20 GMT -5
Why did you relocate the gas tank under the seat? 1. Bigger tank/more Fuel capacity. 2. Gravity Feed cheaper then Pump..lol
Post by afterparty on Dec 28, 2017 22:26:36 GMT -5
That is pretty cool.
