Post by spazter12 on Aug 21, 2018 18:00:08 GMT -5
This looks amazing. 😍😍 The no-stretch is a great twist on a metruck build.
#batterbuild
Post by Happypancake! on Aug 21, 2018 19:16:15 GMT -5
#batterbuild. I like it.
Post by jbjhillbilly on Aug 21, 2018 23:43:12 GMT -5
All together. No stretch Metruck. Need to adjust a few things before complete. Runs ok but has a slight low rpm stutter. Sits way low w/ the 220mm rear shock. OH HELLS YEAH! That’s really effing clean. Well done, sir. As usual, well done! (And look at you, wetting down the driveway for the beauty shot.)
Post by benji on Aug 22, 2018 0:28:39 GMT -5
Cool bike!!
Post by Happypancake! on Aug 22, 2018 6:01:03 GMT -5
All together. No stretch Metruck. Need to adjust a few things before complete. Runs ok but has a slight low rpm stutter. Sits way low w/ the 220mm rear shock. OH HELLS YEAH! That’s really effing clean. Well done, sir. As usual, well done! (And look at you, wetting down the driveway for the beauty shot.) Nah, a thunderstorm went through.
Post by jbjhillbilly on Aug 22, 2018 15:04:00 GMT -5
OH HELLS YEAH! That’s really effing clean. Well done, sir. As usual, well done! (And look at you, wetting down the driveway for the beauty shot.) Nah, a thunderstorm went through. Ah, cool! (we don't get those a lot here in LA)
Post by Happypancake! on Aug 27, 2018 20:02:35 GMT -5
Post by spazter12 on Aug 27, 2018 20:09:03 GMT -5
Those loop pretty dope! 🤙🏼
Post by Happypancake! on Aug 27, 2018 21:36:40 GMT -5
taking notes for future reference. after installing the seat, waffle developed a low rpm stumble. pulled seat then carb and installed new slow jet. started up and idled perfect. put it all back together. next day stumble was back. pulled everything apart and noticed engine would cut out when some wires were moved. turns out the NCY connection was loose which i think was causing the issue. now re soldered in. CANT FIND THE ROLL OF ELECTRICAL TAPE TO FINISH! so note to self, engine stumble, check cdi connection.
Post by Happypancake! on Aug 30, 2018 19:26:16 GMT -5
Drives like i weigh 300 lbs. Time to pull the NB50 gears and put the Ruck gears back in. Couldn’t break 8000 rpm (47mph). Needs some breathing room.
Post by hondalyfe90 on Aug 30, 2018 21:14:38 GMT -5
I got a question, are you still running the break equalizer on any of your scooters?
Post by Happypancake! on Aug 31, 2018 5:03:14 GMT -5
Yes. Posted on your thread
Post by Happypancake! on Sept 1, 2018 8:21:35 GMT -5
Waffle is ANGRY! TIMING IS OFF! Fun fun fun....................
Post by lilpinny on Sept 1, 2018 8:27:35 GMT -5
you should put a gy6 in it and have some fun with that!
Post by Happypancake! on Sept 1, 2018 8:38:24 GMT -5
Best shot I could GET
