Post by Happypancake! on Dec 21, 2017 19:26:35 GMT -5
Here's a built which is still in progress w/ some highlights below: Lost build thread on TR. Original when purchased used : 2004 Honda Metropolitan w/ 100 miles. Pulled motor and installed motor modded w/ eruo FI 4-valve Ruckus Head. FI hole filled in to accept Carb. New bars, TB Exhaust. NB50Gears its ~ 52MPH. @ < 8000RPM Sluggush w/ these gears. Will swap back to Met gears. 4-Valve has a lot more torque.
Post by lilpinny on Dec 21, 2017 20:02:19 GMT -5
I wanna know what difference the 4 valve makes. Stoked to see that.
Post by lilpinny on Dec 21, 2017 20:02:59 GMT -5
You got access to a dyno? Love to see the numbers
Post by Happypancake! on Dec 21, 2017 20:12:22 GMT -5
I still have a long way on the tune. I think I went too far, too fast with the gearing. Winter in the 'burgh now so a bit more difficult to GET out. 1st build hit 60mph b/f I got heavy w/ the 12x7 rear.
Post by Happypancake! on Dec 21, 2017 21:01:45 GMT -5
Post by jbjhillbilly on Dec 22, 2017 1:03:52 GMT -5
Now that you have the new bars on, I'd love to see what the gap between the plastics looks like. If I remember, you are running a Zen Kustomz adapter, and I'm trying to decide if I'm going that route or not.
Post by Happypancake! on Dec 22, 2017 8:29:21 GMT -5
Not done w wiring yet but I'll test fit the plastics and shoot a pic
Post by Happypancake! on Dec 22, 2017 11:06:48 GMT -5
Post by jbjhillbilly on Dec 22, 2017 14:16:30 GMT -5
Thanks Happy! Looks like I'll be picking up the Zen (I was hoping to do without, but it seems like the extra height it absolutely necessary).
Post by hellish100 on Dec 22, 2017 20:31:33 GMT -5
Those bars look so good!
Post by Happypancake! on Dec 22, 2017 23:39:16 GMT -5
You'll need to mod the size of the zen nut hole to fit the mnnthbx stem if u go that way. Just a bit of sanding is needed
Post by jbjhillbilly on Dec 23, 2017 1:35:20 GMT -5
You'll need to mod the size of the zen nut hole to fit the mnnthbx stem if u go that way. Just a bit of sanding is needed Copy that. Thanks again for the pix and info.
Post by pete130 on Dec 24, 2017 8:56:40 GMT -5
Love the back tyer and wheel look mean as from behind i like sleepers dont look that much but turn heads when you nail it on the back wheel
fatkid87
2021 Scoot Tag Champ
Post by fatkid87 on Dec 27, 2017 14:23:15 GMT -5
So you think if I go zen neck I should get zen bars?
Or get mnnthbx neck and bars
Post by lilpinny on Dec 27, 2017 15:07:12 GMT -5
(fatkid, you need an avatar!)
make sure you look at the size of all the stuff you want to work together. for example, I know the JDM neck (and clones) have a different bolt pattern and support bars with a bigger diameter than mnnthbx. The mnnthbx is more BMX sized. The JDM style is all big for those handlebars that hang back.
I tired to put a trail tech device on using a mount that bolts on to the neck, but it was expecting a JDM style neck and wouldn't fit on the mnnthbx neck I had. So now I got a mount I can't use.
