fatkid87
2021 Scoot Tag Champ
Post by fatkid87 on Jul 24, 2018 23:52:57 GMT -5
Ok but how do I not see the speedo wire running down your shield? Did you run it through where you light sits? I think the speedo area is the only thing holding me to stock bars right now I really like the rising sun zen bars but don’t have the 500 to spend on them. Plus I would need the speedo of course so that’s another 100
Post by Happypancake! on Jul 25, 2018 4:43:03 GMT -5
Speedo cable through drilled hole
Post by lilpinny on Jul 25, 2018 7:52:41 GMT -5
How did you mount that speedo? I got a 52mm AFR gauge I want to mount somewhere, but not sure where to put it. My bars are pretty clean but I’d like to hang it off there rather than drill a hole in the box. LP. I think this the mount i used..https://www.amazon.com/Auto-Meter-5202-Mounting-Cup/dp/B000CN9YMK/ref=sr_1_12?ie=UTF8&qid=1532398274&sr=8-12&keywords=autometer+cup Did you just bolt it through the plastics?
Post by Happypancake! on Jul 25, 2018 15:50:35 GMT -5
Yup
Post by jbjhillbilly on Jul 25, 2018 18:33:28 GMT -5
Ok. Finally had a few minutes to myself. Motor back out. Brains and spine removed. Met frame off. Sweet! Is this what you’re wanting the short shock for?
Post by Happypancake! on Jul 25, 2018 19:59:21 GMT -5
Nah. It’s for q*bert
Post by jbjhillbilly on Jul 25, 2018 23:00:31 GMT -5
Copy that.
Post by Happypancake! on Jul 26, 2018 18:10:40 GMT -5
Bye MET dual brake system. Take u too much space.
Post by spazter12 on Jul 26, 2018 19:14:08 GMT -5
Holy crap i didn't know that was a thing! 🤯 Bye MET dual brake system. Take u too much space.
Post by benji on Jul 26, 2018 19:20:15 GMT -5
Yup. I figured it out when I couldn't make mine do a burnout.
Post by Happypancake! on Jul 26, 2018 19:38:06 GMT -5
Brake cables swapped. Decided to put nose back on while I wait for frame bushings
Post by Happypancake! on Jul 28, 2018 11:41:38 GMT -5
Bushings arrived
Post by Happypancake! on Jul 28, 2018 21:49:47 GMT -5
Rear on. Bolts used were 10x30 1.25 pitch. Stock Met bolts are too long.
Post by spazter12 on Jul 28, 2018 21:53:26 GMT -5
Looking good! 🤙🏼
Post by Happypancake! on Jul 28, 2018 22:11:46 GMT -5
PC’d DORF looks great. I need t buy a seat.
