Post by jloi on Jan 4, 2021 14:16:50 GMT -5
seems like you just bought that thing and look at it already .
Post by pinkscoot on Jan 4, 2021 16:25:30 GMT -5
I've owned for almost 3 years but wanted to work on a new project and dragged it out of storage. In November to see if it would run.
Post by jloi on Jan 4, 2021 16:28:51 GMT -5
I guess I'm mixing up scoots
Post by pinkscoot on Jan 9, 2021 18:07:18 GMT -5
I pulled the Gianelli to put back on the SR50 and put the stock back on, I doubt the 50cc cylinder could make the C16 work. Just to see how much Carb tuning I would need to do I started it. Started right up and seemed to rev okay. Hmmm I may not need to do much. Thats a project for tomorrow.
Post by pinkscoot on Apr 17, 2021 17:57:35 GMT -5
Post by pinkscoot on Apr 18, 2021 18:33:15 GMT -5
I got the shroud on and took it for a ride. The 90 main jet and 48 pilot jet were a little big. I had the A/F screw all the way in and it was still too rich. I went to 42 Pilot jet and wanted to go to 88 main but all I had was a 86. I must have 3 of each size in the 70's and 90's but not many 80's. Time for a Treatland order. Took it out and it ran well. It topped out at 8000rpm so I was thinking a CDI limiter. I went from 5.5 gram rollers to 4.5gram and it got up to 8800rpm. I was able to see 45mph indicated. The throttle cable is a little wonky still. I just piled things on the end to get it tight but they are way to janky to work. I think I have a solution but I had to get to work to babysit an orchestra of doctors. Maybe tomorrow evening. I'm debating whats next. The Yasuni 16 or the overange transmission. I know I'm being held back by the CVT so that may be my next purchase. I need to get the revs up to 10,000 rpm for it to get its power. Maybe I throw the Yasuni since I have it. I'll ride it as is for a bit and get it tuned in.
Post by wiscootsin on Apr 19, 2021 9:04:56 GMT -5
are you going to do gears? i still haven't put my 70cc on my et2 because i was hoping to find gears to go along with it.
Post by pinkscoot on Apr 19, 2021 15:58:22 GMT -5
acstorfer
Scoot Newb
Post by acstorfer on May 4, 2021 11:30:07 GMT -5
You're gonna hate me for what I just got. 2001 Vespa ET2 stored for 20 years with 345 miles on it. It even came with the original helmet Shame I can't use it. I SUCK SO HARD!
Post by pinkscoot on May 4, 2021 14:45:48 GMT -5
Congratulations. 20 years you have some cleaning and replacing to do. I wouldn't even try to start it until you drain all of the fluids and replace the belt and air cleaner.
Post by aeroxbud on May 4, 2021 16:30:01 GMT -5
You're gonna hate me for what I just got. 2001 Vespa ET2 stored for 20 years with 345 miles on it. It even came with the original helmet Shame I can't use it. I SUCK SO HARD! Nice find. Like said, I would give it a serious going over before starting it up.
Post by wiscootsin on May 5, 2021 8:00:42 GMT -5
You're gonna hate me for what I just got. 2001 Vespa ET2 stored for 20 years with 345 miles on it. It even came with the original helmet Shame I can't use it. I SUCK SO HARD! and don't take a picture of it with an Icebear in view again. lol
acstorfer
Scoot Newb
Post by acstorfer on May 5, 2021 12:26:02 GMT -5
Congratulations. 20 years you have some cleaning and replacing to do. I wouldn't even try to start it until you drain all of the fluids and replace the belt and air cleaner. All looked at and went over by shop. It runs like new. I have it at a scooter shop now for new tires.
Post by pinkscoot on May 5, 2021 12:34:23 GMT -5
Which tires are you getting. I'm still running on the original front and the old back one from my ET4. Yes I do like living on the edge.
Post by pinkscoot on May 16, 2021 14:17:25 GMT -5
Well I got my Treatland order last week and got the jet swapped to an 88 and put the new CHT plug end on so I can see where the temps are. It was much nicer WOT and mid but a little rough taking off. I adjusted the A/F screw and ended up all the way in. It's fine but maybe just a tad rich. Next time I pull the carb I'll swap it to a 40. meanwhile I'll ride it for the week and see how it feels.
