Post by benji on Mar 31, 2018 11:46:57 GMT -5
So, I've got a malaghuti f18 w a water cooled 150cc motor. Kinda looks like a GY6 of some sort, and is had a disc brake on the rear w a "13 wheel. Should I try to wedge that in here?
Post by spazter12 on Mar 31, 2018 12:19:41 GMT -5
You might have some issues with clearing the plastics with that 13" wheel but why not give it a try?
Post by Happypancake! on Mar 31, 2018 13:16:49 GMT -5
You might have some issues with clearing the plastics with that 13" wheel but why not give it a try? I’m running a 12” fatty no stretch. 13” w low profile might work.
Post by benji on Mar 31, 2018 13:51:33 GMT -5
Maybe after it's running. That motor needs a cylinder and there hard to get and expensive.
My airbox arrived and I ordered the wrong part :/ thought I got a complete airbox, only got the sub-assembly. I already have that. I need the cover and the filter holder thing, as well a filter. I might just throw a Uni filter on there n call it good.
Post by Happypancake! on Mar 31, 2018 21:09:00 GMT -5
Use the stock hose, it’s the correct length. Add a KN. I think I got it from amazon
Post by benji on Mar 31, 2018 21:17:24 GMT -5
You just strapped it on to the oem intake? And then 38/78 on jets to compensate? Sounds easy.. What about all the other stuff plugged into the oem box? Just cap it or remove it?
Post by Happypancake! on Mar 31, 2018 21:28:00 GMT -5
What year is it?
Post by benji on Mar 31, 2018 21:40:12 GMT -5
Already done! fits like a glove
Post by benji on Mar 31, 2018 21:40:26 GMT -5
Post by Happypancake! on Mar 31, 2018 21:42:36 GMT -5
Here's another way w/o air filter.. Crankcase vent: Just add a small filter to it. Hobby shops have them for RC cars. Pair valve: Just cap it. Not needed. All it does is add air to the exhaust during heavy decel Cam Chain Tensioner: if vented , pull off PCV stuff and add small filter. Older Mets, 2004(?) and earlier are not vented nor have the PCV. www.youtube.com/watch?v=CG2hj_1FTBw
Post by Happypancake! on Mar 31, 2018 21:43:08 GMT -5
'06 It's got the PCV then.
Post by Happypancake! on Mar 31, 2018 21:46:54 GMT -5
Here's the set up on AngryWaffle. I connected the carb vent to intake. Not really necessary but it added a bit more throttle response. Ignore the stuff on the right of the carb......experimenting
Post by lilpinny on Mar 31, 2018 21:56:15 GMT -5
The holy air box diagram!
Post by benji on Apr 3, 2018 6:55:53 GMT -5
I think maybe I'll do white and green.
Post by mrkswthwrth on Apr 3, 2018 7:18:55 GMT -5
I likey da greeny
