Post by benji on Apr 4, 2018 9:33:28 GMT -5
Post by Happypancake! on Apr 4, 2018 11:18:30 GMT -5
I have not but at 115mm it might not fit case.
Post by Happypancake! on Apr 4, 2018 11:21:42 GMT -5
I have not but at 115mm it might not fit case. You’ll also need to find a 115mm drive face. Largest I’ve seen is 95mm.
Post by benji on Apr 4, 2018 15:06:46 GMT -5
I have not but at 115mm it might not fit case. You’ll also need to find a 115mm drive face. Largest I’ve seen is 95mm. Good point
Post by jbjhillbilly on Apr 4, 2018 16:22:25 GMT -5
Here's the set up on AngryWaffle. I connected the carb vent to intake. Not really necessary but it added a bit more throttle response. Ignore the stuff on the right of the carb......experimenting Very tricksy!
Post by Happypancake! on Apr 4, 2018 17:10:49 GMT -5
ECU's numbers info: A-20 is an '06 Met - no pcv A-21 started mid '07 - pcv GEZ-67 or 670 is pre06 ruckus (8000 rpm limit - no pcv) GEZ-611 is an 06 or 07 ruckus ( rpm limit - pcv) GET-67 pre-06 met (8000rpm limit) GET-77 is Met2 (7000rpm limit)
Post by benji on Apr 4, 2018 19:11:09 GMT -5
So I need a specific ecu then? Shit...
Anybody know who's got an 'a-20' ecu for sale?
Post by Happypancake! on Apr 4, 2018 19:20:14 GMT -5
So I need a specific ecu then? Shit... Anybody know who's got an 'a-20' ecu for sale? A GEZ-67 and GET-67 will work. The others may also work as the only extra wire to the ecu should be the PCV. I’ll get the wiring diagrams later.
Post by jbjhillbilly on Apr 4, 2018 19:21:36 GMT -5
So I need a specific ecu then? Shit... Anybody know who's got an 'a-20' ecu for sale? I’m working on sourcing one now. Want to make sure yours is roached before that happens. I’ll know more by this weekend (kids at home for Spring Break, so my time is less my own than normal).
Post by benji on Apr 4, 2018 19:21:43 GMT -5
But the earlier ecus have rev limiters, ya? I don't want that haha. I've found a couple of a-20's for sale, I'll pull the trigger as soon as I find out if mine works or not.
Post by Happypancake! on Apr 4, 2018 19:21:50 GMT -5
Also I think the later ecu’s have a 9000 rpm Limit.
All of this info was lost on TR.
Post by Happypancake! on Apr 4, 2018 19:24:12 GMT -5
Post by benji on Apr 4, 2018 19:27:15 GMT -5
DAMMIT I just bought an a20 ecu for $65 off eBay.
Post by Happypancake! on Apr 4, 2018 19:28:40 GMT -5
You still need the ecu
Post by Happypancake! on Apr 4, 2018 19:29:20 GMT -5
Valve float starts at 10,000rpm w stock head
