Post by Fox on Jul 8, 2011 15:31:49 GMT -5
I never liked that style of mirror. Real cheap. Hell, most Chinese made mirrors suck.
Post by ravensguildassasin on Jul 8, 2011 15:38:32 GMT -5
yeah was removing the mirrors and the bolt snapped on both of them. It's ok ill just get a set of the shark speaker mirrors and call it a day.
Post by ravensguildassasin on Jul 9, 2011 3:00:55 GMT -5
ok so broke out the micrometer and well my jet is way to big. around a 100 jet or so. now i need to get a new jet drilled. i needed a #88 jet so its a difference of 0.005 of an inch.
Post by ravensguildassasin on Jul 9, 2011 13:32:49 GMT -5
ok got a new jet but its a #84 i need to upcut it to a #88 to start. going to go buy a #65 drill bit and start from there.
Post by ravensguildassasin on Jul 9, 2011 14:50:28 GMT -5
ok made a o.o35 bit from a sewing needle filed it down till it was right on the money. drilled my new jet and going to go install it hope this fixes the problem. XD
:Edit: took her around the block and she runs the way she was meant to... so 30 mph again. now back to square one making her faster. :scoot:
Post by ravensguildassasin on Jul 9, 2011 17:40:22 GMT -5
ok got her up to 45 downhill and she cut out on me. idk what the problem is but up to that she runs fine all day long. i did remove all the emissions crap when i did the uni filter. any advice would be great.
Post by ravensguildassasin on Jul 9, 2011 18:07:44 GMT -5
did this to my ford a long time ago thinking of doing the same to my scooter. let me know what you all think of the idea.
Post by ravensguildassasin on Jul 10, 2011 0:59:53 GMT -5
:facepalm: i think i know why she cuts out it could be because my CDI is limited yes/no thoughts? .
Post by 90GTVert on Jul 10, 2011 12:46:52 GMT -5
Maybe? I've never had one with a limited CDI that I know of. I assume most just won't let it rev beyond a given RPM, but I wouldn't think it would completely kill the ignition and make the engine die. Any symptoms after or does it just fire back on and continue like nothing happened?
Gauges look good.
Post by ravensguildassasin on Jul 10, 2011 17:21:33 GMT -5
see that's whats odd if i keep bouncing the throttle on deceleration it will come out of it, if i let it die it takes three or so tries to fire back up like it has no fuel left in the bowl.
yeah i used to make them for the zx2 escort community. i miss my escort it was one of my nicest engine builds to date. lol
:Edit: i wonder if the pump is to blame but idk it runs all day at thirty thirty five no problem just topping forty down hill it bogs down and dies if i let it.
Post by 90GTVert on Jul 10, 2011 18:39:22 GMT -5
I suppose you could try setting the float level a little higher and see if it goes away or at least improves, as long as you can do so without affecting the tune otherwise.
Post by ravensguildassasin on Jul 11, 2011 11:13:13 GMT -5
honestly i need a new carb the screws are all striped out on the diaphragm side of this carb.
Post by ravensguildassasin on Jul 11, 2011 14:13:24 GMT -5
well i looked up all kinds of restrictions and so far my scooter has none of them. but I'm confused if it has no restrictions why is 30~35 the fastest i can go on the flat? i feel like I'm missing some important info about my 50cc GY6 engine.
Post by 90GTVert on Jul 11, 2011 14:28:50 GMT -5
30-35 is about normal for a 50cc GY6 on flat ground. I think a lot of the higher MPH claims come from speedometers that are off and/or some that happen to come with larger bores stock.
Post by ravensguildassasin on Jul 11, 2011 15:00:28 GMT -5
thank you i was hopeing it was just misinformation. but as I'm still new it never hurts to here it from a seasoned vet.
