theo547
Post by theo547 on Jul 11, 2011 16:38:35 GMT -5
My wifes gy6 says it goes 40.... Really it tops at 38mph with the needle buried ... Seems like the most you can do with these without buying expensive parts is just increase acceleration. ( after derestriction.)
Post by ravensguildassasin on Jul 20, 2011 19:04:59 GMT -5
finally the shop got my light bulb in.... but the got the wrong one for me not that its really a complaint they got me a 35w/35s instead of a 25w/25w. lol not a big deal but it is the last dime they are ever getting from me. unless i have no other option left.
mccanic
Post by mccanic on Jul 20, 2011 19:43:58 GMT -5
yah i would not go back to the shop, if a shop ever sold me the wrong part id go after them! lol
Post by ravensguildassasin on Jul 20, 2011 20:37:27 GMT -5
yeah he didn't even try to get me the right parts just said well idk what happened man. wtf is wrong with people now.
mccanic
Post by mccanic on Jul 21, 2011 6:34:07 GMT -5
wow! im sorry man! you shouldnt go back to him!! buy from the good stores on the internet.
maccrew
Custom painted f-act
Post by maccrew on Jul 22, 2011 4:49:46 GMT -5
raven you should read in my posts about what the shop did to me.
Post by ravensguildassasin on Jul 22, 2011 13:57:42 GMT -5
last night was my first night ride after the install and wtf i have no low beam but it worked when i put it in. the hell with it im not buying cheap bulbs anymore.
Post by 90GTVert on Jul 22, 2011 15:11:42 GMT -5
If bulbs keep going out, especially when you rev higher, you could have a regulator/rectifier issue.
mccanic
Post by mccanic on Jul 22, 2011 16:32:10 GMT -5
take the bulbs to the auto parts store, i bet they will have one. then you don't have to wait for one to ship in.
Post by ravensguildassasin on Jul 23, 2011 12:35:05 GMT -5
Post by 90GTVert on Jul 23, 2011 15:05:36 GMT -5
I'd try 6g if only choosing one.
Post by ravensguildassasin on Jul 23, 2011 15:17:01 GMT -5
yeah the one comes with 8g and the cvt kit comes with your choice of dr sliders so idk what to do. but i was also thinking 6g or 5.5g.
on a side note i got a strap wrench hopefully that will let me take my cvt apart. i will also be getting a tiny tach. XD
mccanic
Post by mccanic on Jul 23, 2011 16:36:32 GMT -5
that cam really helps getting up and moving. i also read some where that these engines heads were made for the 72cc cylinder but they had to restrick them by putting a 49cc jug on. i don't know if its tune but ive read it at lot of forums? idk
Post by ravensguildassasin on Jul 23, 2011 17:40:09 GMT -5
well that information relates directly to something i read on here. basically it shows that the head is set larger then needed for the 50cc engine. on the flip side it seems to be spot on for the 80cc ish engines. it was a while back that i read it ill see if i can dig up a link.
Post by 90GTVert on Jul 23, 2011 21:01:17 GMT -5
Most stock heads coupled with 80+cc kits create too much compression and heat. They can work well on 70cc kits in some cases. I've heard differing opinions and I think a lot of that depends on the particular engine. Unfortunately all parts aren't created equal in all GY6 50s. I've had valves smack the piston on setups that other people run with no problem. I've had overheating and detonation in setups that others say work great.
