Post by MAReames on Jul 12, 2011 14:28:31 GMT -5
So what is the actual CC of a 90?
Post by 90GTVert on Jul 12, 2011 17:33:42 GMT -5
Mine's an 89cc. 42mmx52mm A lot of us just kinda classify them 50s and 90s though. Larger than stock 49cc stroke and 50mm+ bore I generalize as 90s. Easier than trying to remember what every bore/stroke combo makes exactly off the top of the head.
Post by MAReames on Jul 12, 2011 17:41:17 GMT -5
So my 1E50MF I orderded should be 42mm and 50mm
Post by 90GTVert on Jul 12, 2011 17:47:35 GMT -5
I believe so. The cylinder should definitely be a 50mm. 1E40QMB is a 40mm bore. The cylinder says 1E50FM, which designates a 50mm bore. All the FMs I know of are 42mm stroke.
Post by MAReames on Jul 12, 2011 17:57:35 GMT -5
Any clue where i can fine a fan shroud for this?
Post by 90GTVert on Jul 12, 2011 19:14:15 GMT -5
tango
Ad agendum semper parati
Post by tango on Jul 12, 2011 21:02:13 GMT -5
What you mean intake is located far from head looks normal to me. Are do you mean because it points back instead of forward? 2T engines run their intake into the block, while 4Ts do so into the head. So that's what I meant by the intake being far from the head. I suppose I should have clarified earlier, but it's probably not actually a 90. I just kinda generically call them 50s and 90s sometimes. If it is what I think it is, it would be a 42mm stroke and a 50mm bore, which would be 82.5cc. If I'm correct on the stroke, the addition of a 54mm bore would take it to 96.2cc though. When I looked it up I saw reference to this very engine being a 100 too! The manufacturers seem to be very optimistic at times with their engine ratings.
Post by MAReames on Jul 12, 2011 22:18:30 GMT -5
That would be cool if it was a 100 But I think its a 82cc According to my research.
Post by MAReames on Jul 12, 2011 22:24:25 GMT -5
Thanks for the link but $50 seems over priced anyone happen to have a used one?
Post by 90GTVert on Jul 12, 2011 22:31:28 GMT -5
Just part #3, the actual cylinder shroud, should be all you need if you have the 50cc stuff.
Post by MAReames on Jul 12, 2011 22:35:32 GMT -5
Oh I thought i would need the Fan Cover also.
Post by 90GTVert on Jul 12, 2011 22:40:46 GMT -5
I dunno that it's any different. That shroud doesn't always match up perfect, but it gets the job done. Not sure if both parts would match up better or not.
Post by MAReames on Jul 12, 2011 23:09:07 GMT -5
I guess I will see when my Engine gets here. I cam across this he also has a 1E50FM And put a 54mm Bore and a 47mm Stroke in it. Will that big crank fit with out modding the case?
Post by 90GTVert on Jul 13, 2011 0:06:22 GMT -5
There are some that will I think. The one site selling 47mm cranks that I had definitely heard fir a stock 90 case has been out of business for some time now. Reading over drawkward's posts about his 1E50, I had forgotten that this may be a 10mm wrist pin instead of 12mm like basically all other 90cc stuff uses. That means no 54mm bolt on that I know of. Either way, if it works it's a good deal for an 82.5cc. The cases alone are worth the price, because machining 49cc cases to fit a larger crank will likely cost that much or more.
Post by MAReames on Jul 13, 2011 0:45:06 GMT -5
From what I can tell in the pictures the crank looks to be a 16mm which would have a 12mm wrist pin right? Also do you happen to have a link to that build?
