xzdgx
Post by xzdgx on Aug 6, 2011 0:05:37 GMT -5
I have 4 quarter size holes in my scooter and i want to fill em,im not sure how or whats to use ?Please help me ha
mccanic
Post by mccanic on Aug 6, 2011 7:04:47 GMT -5
Welcome to the forum fiber class (they make a fiberclass past stuff that you can duck tape one side and push it in the over) then bondo over it. good luck!
xzdgx
plastic
Aug 6, 2011 15:00:19 GMT -5
Post by xzdgx on Aug 6, 2011 15:00:19 GMT -5
Thanks man !!!
mccanic
plastic
Aug 6, 2011 15:50:05 GMT -5
Post by mccanic on Aug 6, 2011 15:50:05 GMT -5
no problem!
Post by marshinman on Aug 7, 2011 5:10:47 GMT -5
Go to Wal-mart and in their Automotive paint area they carry a small fiber glass repair kit, it comes with the fiber glass cloth and the resin and hardener. Patch it from the inside with this and then use the bondo from the outside. If price is a concern you can but some aluminum tape at your hardware store and use it on the inside and then bondo on the outside. Make sure you get some rubber gloves when working with the fiber glass, if you get the resin/hardener mix on your hands it will burn as it hardens.
mccanic
Post by mccanic on Aug 7, 2011 8:32:04 GMT -5
i wouldn't do the aluminum tape just seems like after time it will fail, bondo needs something strong to hold onto. i've seen people put cardboard to hold bondo.
plastic
Aug 7, 2011 12:24:19 GMT -5
Post by brandonscoot on Aug 7, 2011 12:24:19 GMT -5
or jb weld/ liquid steel with some type of backing then sand it smooth... ??
bigjeff
just scootin
plastic
Aug 7, 2011 14:06:46 GMT -5
Post by bigjeff on Aug 7, 2011 14:06:46 GMT -5
I use the 2 part epoxy that you can get at lowes in two 8oz bottles. Mix and apply, dries in 10 minutes, totally cured in a couple of hours. tape over one side of the hole and put the epoxy in with a tongue depressor or plastic knife/spoon.
