Evo
Post by Evo on Aug 14, 2011 0:46:29 GMT -5
Post by 90GTVert on Aug 14, 2011 5:39:41 GMT -5
As long as it's tuned properly and the stock exhaust isn't clogged or restricted, it should be fine. I'm sure there are some 50cc tuned pipes out there with small stingers that retain enough heat to be a problem on a 70cc, but I wouldn't worry about a stock pipe. I've managed to use a stock 49cc pipe on a 96cc stroker with ported cases and cylinder. Certainly not my 1st choice, but it was OK. Another style of stock exhaust that I have was exactly the same as what came on my 89cc scoot stock.
Post by jmkjr72 on Aug 14, 2011 9:32:00 GMT -5
you can run an oem pipe you just wont have the performance that you would with an after market pipe i know the yamah aoem pipe works well with bbk or if you are trying to keep the stock look the sp3 is a good pipe too
Post by brandonscoot on Aug 14, 2011 12:05:49 GMT -5
aww man i want that same kit really bad too! it looks nice, cept the coil, dont need that.
now if only i knew my wrist pin size :/
Evo
Post by Evo on Aug 14, 2011 17:50:22 GMT -5
What size main jet should I get?
Post by jmkjr72 on Aug 14, 2011 18:46:47 GMT -5
go up 1 or 2 sizes on the oem mj or the current mj you have if you are sticking with the stock pipe
