Post by scootnewb on Feb 17, 2019 18:38:03 GMT -5
Thanks everyone.
I decided to go with the Key West. The location of the shop/dealer had a lot to do with it. I think though, from what I've read it is also a decent reliable scooter. I wondered though, these have an oil injector but what happens when you goto a 70cc kit? Do you stop using the oil injector and mix the oil with the gas? Cause I imagine the injector won't be pumping enough oil for the bigger 'stuffs'.
Post by Jwhood on Feb 17, 2019 20:34:32 GMT -5
Thanks everyone. I decided to go with the Key West. The location of the shop/dealer had a lot to do with it. I think though, from what I've read it is also a decent reliable scooter. I wondered though, these have an oil injector but what happens when you goto a 70cc kit? Do you stop using the oil injector and mix the oil with the gas? Cause I imagine the injector won't be pumping enough oil for the bigger 'stuffs'. Yeah just switch to premix
Post by benji on Feb 18, 2019 0:34:58 GMT -5
I run oil pumps with my bbks and I haven't had a problem yet. But premix is probably best.
Post by ThomasTPFL on Feb 18, 2019 2:55:43 GMT -5
I don't 100% trust the TGB injection. Id run like 1% premix with a kitted engine to be safe and jet accordingly. That's what I'm doing with my current bike.
I've killed one TGB engine due to bearing failure and one due to apparent oil starvation. YMMV.
Post by scootnewb on Feb 18, 2019 3:36:36 GMT -5
Was the bearing failure related to having a BBK?
Post by ThomasTPFL on Feb 18, 2019 10:04:45 GMT -5
Was the bearing failure related to having a BBK? Most likely due to being an old pizza delivery bike with who knows how many miles and lousy maintenance. It was taken apart and neglected when I got it. I threw a Malossi 47mm kit on I and got a thousand or so miles out of it before the flywheel side bearing got super noisy.
Post by pinkscoot on Feb 18, 2019 11:35:08 GMT -5
The TGB's in the 2006-2208 2008 range had a design flaw with the injectors that caused bearing failure. It was all about where it injected the oil to the crankcase. If I recall it had 2 points and the switched the intake so it had 1 point. I would think they have solved that by now.
Post by scootnewb on Feb 19, 2019 17:47:50 GMT -5
Ugh, I ended up getting the Bullet 50. I saw the rear wheel disk brake etc etc and thought why not. I hate buying shit. I always sperg out and leave with something I didn't really want.
Post by fugaziiv on Feb 19, 2019 18:04:15 GMT -5
Ugh, I ended up getting the Bullet 50. I saw the rear wheel disk brake etc etc and thought why not. I hate buying shit. I always sperg out and leave with something I didn't really want. Bullet is a good looking bike though. Matt
Post by scootnewb on Feb 19, 2019 18:18:42 GMT -5
Yeah, I saw the shiny, the rear disk brake, digital console and thought,"Why not?". I mean it has the same engine as the Key West and the big thing was the 13 inch wheels. On my Tao Tao I remember thinking how much better it would be with 12 inch wheels. Hitting bumps, especially if I was riding to the right letting traffic pass, was really sketchy cause the streets around here are bad. I'm hoping my purchase decision wasn't too bad. I'm not seeing many posts about this scoot on any English forums.
Post by pinkscoot on Feb 19, 2019 18:36:26 GMT -5
They look to be the RX50 rebranded as the Bullet: moto.zombdrive.com/tgb/2006-tgb-r50x.html. I have a couple of scoots with the 13" wheels and dual disc brakes. They are a great way to go. When you make it go fast you'll be happy to not be rolling on 10" wheels. Congrats I think if you you have a good reliable 50cc scooter now.
Post by scootnewb on Feb 19, 2019 19:04:55 GMT -5
Thanks man. So excited about this.
Post by ThomasTPFL on Feb 19, 2019 23:53:01 GMT -5
If I remember correctly the Bullet has a 11:1 vs 15:1 final drive like the Key West, easier to get speed out of when you start modifying the engine.
Post by scootnewb on Feb 20, 2019 0:57:29 GMT -5
Cool. Do you happen to know the 'restrictors' on the Bullet? I've been reading conflicting information. Some say it is the CDI, variator and a brass ring (not sure where that is, maybe on the exhaust?). Some say replacing the CDI did nothing.
What other engine mods are there besides the 70cc? I am not sure I can would be able to port it.
Post by ThomasTPFL on Feb 20, 2019 10:22:04 GMT -5
You'll have to physically look at the exhaust and variator to see. I'd recommend a sport exhaust of some sort anyway just as the stock is restrictive in general.
If it's CDI restricted you will know it. It will hit a certain rpm and lose all it's oomph.
