kglazer
Post by kglazer on Sept 1, 2011 17:45:00 GMT -5
How could the timing be Off if i never changed the timing?
kglazer
Post by kglazer on Sept 1, 2011 17:55:44 GMT -5
and its been eating through gas alot since the bbk like half a tank gone with the 50 miles i rode
tango
Ad agendum semper parati
Post by tango on Sept 1, 2011 17:59:48 GMT -5
Something could have shifted the pickup, I would imagine. This could have been caused by a loose bolt, something bent, or something broken. I'm not 100% sure about this but perhaps the issue is with the CDI itself, since that's the unit that actually triggers the spark after receiving a signal from the pickup.
Post by 2strokd on Sept 1, 2011 18:28:41 GMT -5
Checked the reeds?
Post by jmkjr72 on Sept 1, 2011 18:32:54 GMT -5
+1 on the reeds last time i had a 2 stroke backfire i had chunked a reed
unless you had fly wheel off its real hard to bust a key way to fubar your timeing
kglazer
Post by kglazer on Sept 1, 2011 18:36:03 GMT -5
what should i check the reeds for like out of place or cracked? should i go get some starter fluid and spray some in the intake of the carb and try and start it?
Post by 2strokd on Sept 1, 2011 19:56:49 GMT -5
Take the intake off and pull the reedblock and look for chips, cracks, chunks missing, etc...
kglazer
Post by kglazer on Sept 1, 2011 20:54:42 GMT -5
ok. it would not start with starter fluid sprayed into the inlet of the carburator
tango
Post by tango on Sept 1, 2011 21:44:03 GMT -5
Don't worry about the starter fluid until you have checked the reeds as recommended above. If you hold the reed block up to a light source and you can see light anywhere through it then that would be a problem.
Starter fluid is only used as a substitute for fuel, such as if your carburettor or fuel system is not working properly. Checking the reed block isn't a check for fuel flow to the combustion chamber, it's a check that fuel that has already been injected is staying there. In other words, if your reed block is leaking then fuel, and subsequently combustion gases, are getting back to the intake system. That's another type of backfiring that I failed to mention in my previous explanation. Clearly, this type of backfiring can be more dangerous since hot gases are being exposed to incoming fuel.
kglazer
Post by kglazer on Sept 1, 2011 21:50:08 GMT -5
ill check that tomorrow morning when i get back from class
kglazer
Post by kglazer on Sept 3, 2011 0:11:22 GMT -5
i checked the reeds.. seem fine Cleaned the carb and put a new jet in... seems fine checked for spark... seems fine checked to mae sure kill switch is off..... yes wtf is going on with my scooter it will not start jsut keeps turning over and over
Post by 2strokd on Sept 3, 2011 7:08:36 GMT -5
Is it getting spark now? Is the plug sparking if you pull it out and turn it over?
Tried kickstarting it? Or are you using the electric start? Sounds silly but sometimes a quick sharp snap of the foot on the kickstarter will do it! We can kick em over much faster than the ele start will spin it...
kglazer
Post by kglazer on Sept 3, 2011 8:52:35 GMT -5
i have tried kickstarting it with no success. it is getting spark right now
Post by 2strokd on Sept 3, 2011 9:02:05 GMT -5
Tried a new plug yet? Spark might not be very strong from a weak plug? Compression there? I dunno man, just thinking out loud at this point.... This scooter did run tho right? I mean, the way it is set-up as it sits?
kglazer
Post by kglazer on Sept 3, 2011 9:19:24 GMT -5
yes it ran perfect!!!Then just would die when coming to a stop. then it would start right back up. then it died again when i stopped and will not start yet. it has compression. i guess i could try a new plug?
