kglazer
Post by kglazer on Aug 30, 2011 21:51:48 GMT -5
hey guys i jsut installed the 72cc cast iron kit for my kymco super 9. i have gone through about 50 miles or so and have taken it pretty easy on it for break in but a few times i let her go wot for a couple seconds to see what a the diffrence was between 50cc vs 70cc. my top speed was 42mph which is only about 3 mph faster then stock. So what gives?
i have a technigas next r pipe, 1000 contra, 1500 clutch springs, 5 gram rollers, and im pretty sure stock belt going on about 6300km and running 32:1 premix
Post by jmkjr72 on Aug 30, 2011 22:10:04 GMT -5
what cdi are you running from what i under stand you cant fully derestrict the oem cdi and are you jetted properly for a sport kit i would just do 40:1
Post by jmkjr72 on Aug 30, 2011 22:11:30 GMT -5
kglazer
Post by kglazer on Aug 30, 2011 22:32:47 GMT -5
I have the oem cdi. I have fully derestricted it except for the cdi and i have upjetted to a 88 jet. Would the premix ratio rlly make a diffrence on the power. Im thinking its just the oem cdi is not letting it rev high enough to make more power
lbo
Post by lbo on Aug 31, 2011 13:28:53 GMT -5
I don't know about the CDI, my stock (just a pipe) AC Super 9 would hit 48 and cruise at 45. (GPS #'s, speedo 50+)
Something else seems amiss. The boss restriction would have you at 30MPH and sounds as though that has been removed. You have the same pipe I do on mine. I would guess the issue is in the CVT somewhere or the carb needs to be tuned. Just a guess......... maybe your belt has stretched?
kglazer
Post by kglazer on Aug 31, 2011 13:41:24 GMT -5
what weight rollers do you have in yours lbo? yeah idk whats up with my scooter honestly its jsut lacking so much power idk why. and today it dies on me when i came to a stop. and then again it did it and would not start back up? i have no idea why both times i had to push it home. How do i get it started again?
kglazer
Post by kglazer on Aug 31, 2011 22:41:45 GMT -5
What could be causing the scooter to die when coming to a stop. Flooding the engine when off the throttle?
tango
Ad agendum semper parati
Post by tango on Aug 31, 2011 23:20:59 GMT -5
I'm eager to hear the answer to this one myself. If it's flooding the engine at idle I would be thinking that your idle mixture would be too rich or perhaps your enricher has gone bad. But are you sure it's flooding, or are you supposing?
kglazer
Post by kglazer on Sept 1, 2011 7:31:01 GMT -5
When i get off the throttle the idle goesbway down and the motor just dies and will not start back up. It crancks but doesnt turn over. The second time it happened i cant get it to start at all it still wont start i put both screws all the way in the carb and then turned the idle to 2.5 turns and the other one to 2 turns and it still wont start
Post by jmkjr72 on Sept 1, 2011 14:44:58 GMT -5
When i get off the throttle the idle goesbway down and the motor just dies and will not start back up. It crancks but doesnt turn over. The second time it happened i cant get it to start at all it still wont start i put both screws all the way in the carb and then turned the idle to 2.5 turns and the other one to 2 turns and it still wont start it cranks but it doesnt turn over :lol: sorry if the engine is rotating it is turning over so do you mean it cranks but doesnt fire what does the plug look like if its wet its flooding if its dry your probelm is else where did you try starting fluid when you couldnt get it to start did you try holding the throttle open are you sure you dont have an air leak some where
kglazer
Post by kglazer on Sept 1, 2011 15:51:09 GMT -5
it does crank and turn over it doesnt fire lol. i havent been able to get the plug out as i dont have a deep socket enough to remove it. i havent tries starter fluid as i dont have it and i have tries with holding the throttle open and no success. The intake gasket does have a small rip in it? so it could be a air leak but would it start up 2 times and then not start at all due to a air leak?
Post by jmkjr72 on Sept 1, 2011 16:46:17 GMT -5
just like in a car a small air leak or vacuum leak can quickly become a big one if you didnt change the piolt jet and your still on the oe carb i doubt you are flooding heck you have 50 miles on the build i cant imagine going 50 miles on a build without doing so plug chops or at least checking the plug i would also consider a compresion check as you could have tossed a circlip and tore things up
kglazer
Post by kglazer on Sept 1, 2011 16:59:48 GMT -5
i highly doubt i tossed the circlip cuz it runs fine when its on it wouldnt do that if it lossed a circlip. im going to check the plug tomorrow. im thinking of trying starter fluid tonight i just heard mix reviews on using starter fluid on 2 strokes. cuz it doesnt have lubrication
kglazer
Post by kglazer on Sept 1, 2011 17:24:27 GMT -5
It backfires when i try to start it by the electric or kick start what does that mean
tango
Post by tango on Sept 1, 2011 17:40:54 GMT -5
Usually a backfire is caused by a flame in the exhaust pipe brought about by one of several things, usually ignition timing. But a burnt or improperly seating exhaust valve can cause that too. Since your scoot is a Mineralli-style 2T there is no exhaust valve (though some 2Ts do have exhaust valves) so I would be pointing to a problem with your ignition timing.
