Post by Jwhood on Apr 7, 2020 15:01:14 GMT -5
I'm glad to hear it worked out, I was feeling guilty. You good pink I wouldn't even of seen it either if i wouldn't of took the entire bike apart it's all covered by the shroud
Post by pinkscoot on Apr 7, 2020 15:45:50 GMT -5
Thank you, I guess while you have it apart a new crank?
Post by Jwhood on Apr 7, 2020 17:05:58 GMT -5
Thank you, I guess while you have it apart a new crank? Maybe, Honda has great cranks but if I have to I will hoping it's not really screwed up I might make a mini stroker if I do
Post by Jwhood on Apr 13, 2020 12:42:34 GMT -5
Post by Jwhood on Feb 4, 2022 14:15:46 GMT -5
Well finally after 2 years almost... finally found cases they are in route now will finally put this thing together in the coming month
Post by Jwhood on Feb 12, 2022 11:33:27 GMT -5
Repeat.......i say repeat the eagle has landed
Post by Jwhood on Feb 12, 2022 11:36:52 GMT -5
Gotta get some new tools left alot at my old house going today to grab those and start on this thing finally,you think muratic acid would be safe on these cases there really greasy,dont wanna hurt the case tried purple power and simple green before didnt like the job they did and recommendations on good cleaner
Post by oldgeek on Feb 12, 2022 15:24:49 GMT -5
Gotta get some new tools left alot at my old house going today to grab those and start on this thing finally,you think muratic acid would be safe on these cases there really greasy,dont wanna hurt the case tried purple power and simple green before didnt like the job they did and recommendations on good cleaner Pressure wash and or elbow grease. I would not use anything harsh at all, especially muriatic acid. Blasting with beads or walnut shell media is another way to do it.
Post by Jwhood on Feb 16, 2022 17:51:05 GMT -5
They cleaned up well might paint the cases
Post by Jwhood on Feb 16, 2022 17:54:30 GMT -5
cleaned up
Post by oldgeek on Feb 16, 2022 22:07:09 GMT -5
Its good to see you finally got your hands on a decent, usable set of cases.
Post by Jwhood on Feb 16, 2022 22:11:27 GMT -5
Its good to see you finally got your hands on a decent, usable set of cases. These damn things are getting hard to find or someone wants $400 + just for cases
Post by Jwhood on Apr 7, 2022 8:36:20 GMT -5
Had the day off cause the rain we been swamped at work, decided to button the engine up,also put new gears and gave it a all black under coating cause the cases looked like shit, waiting on a mount from japan cause i lost the original when i moved and also a new floor board cause the one i have is all janky and cracked almost at the finish line only thing left to do is paint the frame a matte black and start mounting and tuning hopefully will be able to get it together so i can ride down ocean city this year its been a long time coming
Post by Jwhood on Apr 7, 2022 8:53:51 GMT -5
also found the elusive ncy stem the original one brand new not the newer version that ppl were having issues with also bought a pair of spare wheels incase i wanna swap wheels some times
Post by 808ministroke on Apr 7, 2022 22:21:07 GMT -5
also found the elusive ncy stem the original one brand new not the newer version that ppl were having issues with also bought a pair of spare wheels incase i wanna swap wheels some times NOICE!
