Post by Deleted on May 18, 2012 19:53:49 GMT -5
Are you using the 139qmb stroker crankshaft also?
Post by theswede on May 20, 2012 13:56:14 GMT -5
No, no stroker crank. Plain 72cc, as in my sig. Lots of hills around here...
Post by Deleted on May 20, 2012 14:42:02 GMT -5
No, no stroker crank. Plain 72cc, as in my sig. Lots of hills around here... i have signatures disabled sorry didnt see.
Post by Deleted on May 20, 2012 15:06:42 GMT -5
brake for a 150 helped a lot ? show this please
Post by larry001964 on May 20, 2012 15:35:25 GMT -5
ok Ill get a picture of it. and get it up as soon as i can. It's a little difficult at the moment... Not sure how to upload the pic from my smartphone to photobucket.. Ill figure it out
Post by Deleted on May 20, 2012 15:39:46 GMT -5
Post by larry001964 on May 20, 2012 15:59:05 GMT -5
what kind of electrical draw will that have ? trust me you will need every amp you can get to start it..
Post by Deleted on May 20, 2012 16:23:27 GMT -5
3 amps. it will be running only when the engine is. it will be hooked to 1 of the 2 230cca 14ah batteries i will have. one in the stock location and another under the seat...both using 10ga wire to the starter relay from both positive terminals on each battery (totaling 4 runs of 10ga... 2 of which will only be less than 6 inches in length) 49ccscoot.proboards.com/index.cgi?board=builds&action=display&thread=3060see page 3
Post by ososlow on May 20, 2012 22:45:36 GMT -5
Hey larry, what up? so what did it take to get the crank to fit in the case?
Post by Deleted on May 20, 2012 23:13:49 GMT -5
He doesnt have a PC right now hes been using a smartphone. Anyway....the crank is a drop in part...no case mods needed. Takes some other things though like additional base gaskets under the jug....and some variator work.
Post by ososlow on May 21, 2012 0:00:03 GMT -5
Post by Deleted on May 21, 2012 0:14:59 GMT -5
thanks I already have a Naraku 52mm bore kit coming but yeah that head is one of the ones im looking at
Post by Deleted on May 21, 2012 0:15:41 GMT -5
Post by ososlow on May 21, 2012 0:53:59 GMT -5
Actually, I ment if larry puts the 52mm head on his 50mm jug, then it should help him on his quest for lower compression.
Post by larry001964 on May 21, 2012 6:50:30 GMT -5
Guess im getting old. Looked thru my parts pics last nite and i discovered an error. My jug is a 52 mm. My head is 50 mm. ALL NCY parts
That may explain some of my high compression.
