Post by Deleted on Jan 5, 2012 19:38:30 GMT -5
I was thinking the same, but then I don't see any indication that the display could change to miles... like you notice with the other digits that can change. I contacted racing planet about it but even if it doesnt read miles i gotta have it. its a direct bolt on QT replacement, only one I have ever seen.. its just too cool to not get. I can pretend the kph is mph lol i'll be flyin then...and not be.
Post by Fox on Jan 6, 2012 17:30:41 GMT -5
Maybe it's got a switch inside to change it to read MPH.
Post by Deleted on Jan 21, 2012 15:38:53 GMT -5
Nothing much to report lately. I did aquire a good working 'Da Shun' stock 24mm carb off a wrecked but running 150 that im going to use, and i already had the 105 and 115 jets. Sorry for the low quality photo.
Post by Deleted on Feb 11, 2012 7:30:57 GMT -5
Got this in the other day but I dont have a demel to get the restrictor out, gonna have to buy one I guess.
Post by 90GTVert on Feb 11, 2012 9:31:50 GMT -5
I didn't even know LV restricted it's 4T pipes. Is it the little funnel type in the header?
Post by Deleted on Feb 11, 2012 10:05:26 GMT -5
yes 2 spot welds in there holding it in
Post by 90GTVert on Feb 11, 2012 10:35:30 GMT -5
A Dremel is great to have, but if you don't wanna get one ATM you can use a chisel to get it out. You can file or use a burr in a drill to smooth it out if you are so inclined.
Post by Deleted on Feb 11, 2012 10:49:25 GMT -5
true. i had 2 demels that got burned up with everything else in the fire a few years ago. it sucks to go spend money to replace all the things i had before that took me years to build up. ive been needing a dremel ever since though so when the Baja sells im gonna go get a dremel.
vvtr
Post by vvtr on Feb 11, 2012 11:20:05 GMT -5
i just bought a silverline 'rotary hobby tool' on ebay. theyre dirt cheap & this is the 2nd one ive had, but for the price you can afford to trash one every few years. i didnt realise they have a 2 year warranty lol they come with a good selection of bits - the flexible shaft is a good accessory too especially if you intend doing any port or casing work
Post by Deleted on Feb 18, 2012 3:23:49 GMT -5
I beat on that restrictor with a chisel then had a thought, since its just one spot weld why not just stick the chisel in the thing and wiggle it back and forth to break the weld? Viola! Came right out. The photo above is misleading, with the muffler bracket on the top like that you would have room to get the dipstick out but thats not how it bolts up, the bracket mounts on the bottom not the top. It looks great but its too loud. People turn and look...which I dont want... and checking/adding oil is impossible. The muffler must be unbolted and removed to get the dipstick out The header flange would have to be cut and re welded at a different angle to mount the system as pictured so the dipstick could be removed but then i would worry about it scraping the ground on a right turn Great system for a race bike that would be on the track or the rack all its life. Not a system for the daily driver. It will be fine for Project Stroker 95 since that bike will not be a daily driver it will be a weekend cruiser only. Also it offers no performance gain on a motor with a stock head, cam and carb. This exhaust was bought for Stroker95, Midnight will not have this system on her long, tooooo loud for a tagless 82cc daily driver :light: . I couldnt leave it in the box though I just had to run it a little
Post by 190mech on Feb 18, 2012 6:05:13 GMT -5
It does sound good!Its a shame a big company like L V couldnt design a pipe that allows access to the very important dip stick!! :stumped:
Post by 90GTVert on Feb 18, 2012 6:46:43 GMT -5
That's more like what I'd expect out of some off-brand eBay type stuff. Looks and sounds good though.
Post by lshigham on Feb 18, 2012 9:50:47 GMT -5
Enviro says you can get the dip stick out, but it's a little fiddly. I never was though. I've still got one of these in my loft from my 139QMB days.
Post by Deleted on Feb 18, 2012 10:13:42 GMT -5
Enviro says you can get the dip stick out, but it's a little fiddly. I never was though. I've still got one of these in my loft from my 139QMB days. The force is not with me like it is for ObiWan Enviro. I am more like Bones McCoy..'Im not a miracle worker Jim'!
Post by lshigham on Feb 18, 2012 10:52:05 GMT -5
Yes - I found it impossible too, wasn't just me then!
