Post by Deleted on Dec 25, 2011 23:54:21 GMT -5
the T1 VW drag racers eliminate the mechanical fan and fan shroud and run an electric squirrel cage fan for more power/better cooling. I am considering this since tall gears and a 13" wheel is going to slow stock fan rpms down. anyone ever seen this done or done it yourself?
Post by larry001964 on Dec 25, 2011 23:59:33 GMT -5
I've never done that, but Hoca does have a high performance fan to replace the stock one, that's the one I'm using..
Post by Deleted on Dec 26, 2011 0:06:11 GMT -5
do you see any difference in the way its constructed?
Post by larry001964 on Dec 26, 2011 0:11:40 GMT -5
do you see any difference in the way its constructed? Yea, the fan is just a little bigger, the fins in the squirrel cage are smaller in general but a few of them are a little longer.. Just looking at it i think it's designed to blow more air but create less drag.
Post by Deleted on Dec 26, 2011 0:25:31 GMT -5
Post by larry001964 on Dec 26, 2011 0:31:47 GMT -5
I'm doing 58 now and still tweaking it. I'm sure I can top 60 or better when i em completely finished, i can still go up to a # 95 main jet, and I still have to get heaver weights in the variator.. so I still have things to do before i have reached it's top speed.
Post by Deleted on Dec 26, 2011 1:38:50 GMT -5
i saw you are using a stock airbox i dont know if thats for appearances but if its tagged why worry. the exhaust is a dead giveaway anyhow. you should be able to go higher than a 95 with a uni filter.
Post by Deleted on Dec 26, 2011 2:57:43 GMT -5
most of these boys here are into drag racing but ive never really been that type of racer, I am a top speed/endurance/road racer. oh the trouble that gets you in but ive had some great runs lol
Post by larry001964 on Dec 26, 2011 9:29:52 GMT -5
i saw you are using a stock airbox i dont know if thats for appearances but if its tagged why worry. the exhaust is a dead giveaway anyhow. you should be able to go higher than a 95 with a uni filter. To be honest, I don't like uni filters, too much maintenance on them. The stock airbox is a good design, keeps water and dust out, so I used it, used a piece of flex pipe from the carb to the airbox, and drilled a couple of holes in the bottom of the airbox cover. I can control my A/F this way. Tagging it is in process...
Post by Deleted on Jan 3, 2012 20:31:54 GMT -5
Post by jmkjr72 on Jan 3, 2012 21:14:16 GMT -5
it will be interesting to see how this motor is geared being a 50cc with a 13" wheel. a 50cc has a hard enough time turning a 10" rim size has nothing to do with it it will be the over all tire size a 130/90 10 130/70 12 and 130/60 13 are all the same size (well give or take a bit from one brand to the other becuase of thread)
Post by Deleted on Jan 3, 2012 21:43:41 GMT -5
i guess i could just imagine its MPH and that would be seriously fast lol
Post by Deleted on Jan 4, 2012 11:57:23 GMT -5
if anyone sees one of these that reads MPH please let me know
vvtr
Post by vvtr on Jan 4, 2012 15:22:36 GMT -5
most digital dashboards wi display both... might be worth asking the seller of try find a user manual for it online.... like its probably a setting or something that you can select.
Post by 90GTVert on Jan 4, 2012 23:17:22 GMT -5
I was thinking the same, but then I don't see any indication that the display could change to miles... like you notice with the other digits that can change.
