Post by speedy1125 on Oct 25, 2011 18:27:19 GMT -5
maybe kat was right bad connections at the cdi plugs.... i had the cdi box off but i went and plugged it back in the picked into the orange wire from the key to check it again. It had 13.5 on it with the battery charger on it, i dont recall seeing that much this AM. anyway when i saw that i spun it over and heard the plug sparking (it was hanging below plugged into the wire) It will run if i shoot starting fluid in it but when thats depleted it dies. it has oil and gas in the tanks new fuel line and filter. does the sensor in the oil tank kill spark when it trips or does it just turn a light on? by spark i mean good spark too it shocked the piss outta me
Post by 90GTVert on Oct 25, 2011 18:34:10 GMT -5
by spark i mean good spark too it shocked the piss outta me So that's how you determine good and bad spark!?! Careful using this method if you have a heart condition, pacemaker, or a lack of Depends.
Post by speedy1125 on Oct 25, 2011 18:36:27 GMT -5
it has a manual choke also.
Post by speedy1125 on Oct 25, 2011 18:40:38 GMT -5
by spark i mean good spark too it shocked the piss outta me So that's how you determine good and bad spark!?! Careful using this method if you have a heart condition, pacemaker, or a lack of Depends. haha well no i was touching the plugwire when i spun it over and for some reason it jumped on me :zap: i will have to look into that later but right now im wondering why it does now have (a) spark suddenly and (b) why i have to use starting fluid for it to fire up. obviously im not going to continue shooting oil-less stating fluid into it and i dont know jack about 2 stroke carbs. this is a good opportunity to learn on 2-strokes. how to proceed??
Post by 90GTVert on Oct 25, 2011 18:51:55 GMT -5
A 2 stroke carb is easier than the CV stuff on the 4Ts. Check the float height and make sure it's clean. Check operation of the petcock, same deal as the 4T there.
Intermittent spark will probably be a PITA. Loose wires, kill switch problem, plug cap/wire getting loose, air gap...
Post by thunderkat59 on Oct 25, 2011 19:00:26 GMT -5
Jut saw PM, speedy ! :rockon: *w00t* Very cool ! Glad this might have worked for you. :thumb: My Beamer with manual choke loads up too too easy. It usually--98%-- starts one or two kicks. If it goes into 4 kicks, gets real "iffy", if more than that, yer pushing ! :doh: My routine is 1/3 choke, use electric starter or kick twice. If it goes more than that, its probably loaded up. If it loads up, pull plug, hours to dry out. It isnt going to start. I say pull plug, let it dry over nite. If you weren't getting spark, but were getting gas, there is a huge probability its swimming in fuel. In the morning, a clean plug and dry bottom end will be a better indicator. :zap2: Good luck and keep us posted :cheers:
Post by speedy1125 on Oct 25, 2011 19:04:42 GMT -5
Jut saw PM, speedy ! *w00t* Very cool ! Glad this might have worked for you. My Beamer with manual choke loads up too too easy. It usually--98%-- starts one or two kicks. If it goes into 4 kicks, gets real "iffy", if more than that, yer pushing ! My routine is 1/3 choke, use electric starter or kick twice. If it goes more than that, its probably loaded up. If it loads up, pull plug, hours to dry out. It isnt going to start. I say pull plug, let it dry over nite. If you weren't getting spark, but were getting gas, there is a huge probability its swimming in fuel. In the morning, a clean plug and dry bottom end will be a better indicator. Good luck and keep us posted its not loaded. if i shoot starting fluid into it it will run until the starting fluid is depleted.
Post by speedy1125 on Oct 25, 2011 19:09:28 GMT -5
A 2 stroke carb is easier than the CV stuff on the 4Ts. Check the float height and make sure it's clean. Check operation of the petcock, same deal as the 4T there. Intermittent spark will probably be a PITA. Loose wires, kill switch problem, plug cap/wire getting loose, air gap... easier when you know what you are looking at, i dont lol Petcock works i checked it the other day. this carb has more screws like a thumb screw that a cv carb doesnt have, along with a vac. line that i dont know what its for. i am out of my element now but its time to learn about 2-stroke carbs.
Post by 90GTVert on Oct 25, 2011 19:16:43 GMT -5
Post by speedy1125 on Oct 25, 2011 19:21:14 GMT -5
ok the float bowl drain i opened that up the other day and no gas came out only oil. this tells me the floatbowl is empty. why would this be? im thinking stuck float
Post by speedy1125 on Oct 25, 2011 19:26:29 GMT -5
also whats that other vac line for? oil pump?
Post by 90GTVert on Oct 25, 2011 19:38:14 GMT -5
Float issue or vacuum/fuel system problem. Perhaps you've got a line in the wrong spot? Looking at the image below, the nipple to the left of the idle screw labeled is the oil line from the pump. The nipple sticking straight up on the manifold side of the carb is a vacuum source.
Post by speedy1125 on Oct 25, 2011 19:44:45 GMT -5
lines are connected to the correct ports. float bowl is empty, no gas comes out only a little oil.
Post by 90GTVert on Oct 25, 2011 19:58:39 GMT -5
You're gonna need to pull the carb off and check it out if you've already verified fuel makes it all the way to the carb. You could try tapping the bowl with something, but if it's sticking it should still be taken apart and cleaned.
Post by speedy1125 on Oct 25, 2011 20:01:03 GMT -5
yeah i tapped and tapped and tapped some more. still no gas in the float bowl. tomorrow i will disassemble. Thanks bro.
Its been sitting since just before Hurricane Irene so the carb is probably full of crap.
