Post by jglen00 on Jan 25, 2021 19:14:30 GMT -5
Whenever I installed the new jug and piston I just installed it where it was currently resting. I saw no marks to line for TDC or BDC, and I was under the impression that this step wasn't necessary on a 2t. Is this correct?
Post by pinkscoot on Jan 25, 2021 19:20:32 GMT -5
The best way to check compression is to use the kick start with the throttle open. Another tip is that the HF Pittsburgh testers do not give you an accurate reading on a scooter. The best I ever got was 30 psi yet the engine would start and run fine.
Post by aeroxbud on Jan 25, 2021 19:28:26 GMT -5
Your correct. No valves on a two stroke, so doesn't need to be set at TDC.
Post by jglen00 on Jan 26, 2021 0:15:54 GMT -5
The best way to check compression is to use the kick start with the throttle open. Another tip is that the HF Pittsburgh testers do not give you an accurate reading on a scooter. The best I ever got was 30 psi yet the engine would start and run fine. That is interesting. Ppl really seem to be down on this yrster
Post by repherence2 on Jan 26, 2021 16:36:04 GMT -5
I still can't figure out why the flywheel is turning backwards. What's to happen when I get it running,I'll be riding it in reverse everywhere? This is the first two stroke I've worked on and I'm becoming very irritated. Many thanks for your involvement in helping Hang in there. We all have been irritated the first time we worked on our first 2 stroke.
Post by repherence2 on Jan 26, 2021 16:41:54 GMT -5
Hello to all,
I'm trying to get my D1E41QMB Qingqi 50cc running again. I tore everything apart after the engine shut off from lack of oil. After everything was taken off I'd decided to just go with premix. I broke the jug on accident and I had alot of trouble getting the new piston into the new jog. Turns out it's hanging up in the crankcase. Any quick answers? I've provided a video to further illustrate
Many, many thanks
What do you mean by, "i broke the jug on accident"? When you say you had trouble getting the new piston into the jug, did you damage/break the piston ring(s)?
Post by jglen00 on Jan 26, 2021 17:23:42 GMT -5
Hello to all,
Many, many thanks
What do you mean by, "i broke the jug on accident"? When you say you had trouble getting the new piston into the jug, did you damage/break the piston ring(s)? I broke the jug in a seperate incident. It didn't happen by me trying to force it onto the piston. I examined the rings and they appeared to be in working condition
Post by jglen00 on Jan 26, 2021 17:26:57 GMT -5
Apparently a 2t motor that switches direction is not a phenomenon or supernatural. But on this particular scooter which has no CDI, no TDC, or any ignition timing that I can see, I can't figure out how it suddenly started going in reverse
Post by aeroxbud on Jan 26, 2021 18:40:06 GMT -5
I have seen it before when the ignition timing is out. But unless the pick up has moved and come loose, it seems unlikely.
Post by captincvmn on Jan 26, 2021 19:25:02 GMT -5
Ignition timing wouldn’t explain backwards rotation of the starter motor.
Post by aeroxbud on Jan 27, 2021 4:58:28 GMT -5
That's when it's actually running. Not just turning over.
