Post by brandonscoot on Oct 27, 2011 16:55:17 GMT -5
so when i run with the choke off it idles really well but bogs badly off the line.
with the choke on it has good take off but top end is affected.
the jets are those un labeled ones that come on the kwihin pwk. the clip is on 2/5 position, 1 notch from the bottom
any tune-ing ideas?
Post by brandonscoot on Oct 27, 2011 16:55:53 GMT -5
also... the exhause it way tooooo loud, has anyone encountered this problem?
Post by 90GTVert on Oct 27, 2011 17:37:50 GMT -5
Any time you need to use the choke, the tune is too lean. If the top end is only affected with the choke on, you're too lean on the main jet. If I turn the choke on with my manual choke carbs, top speed is not only affected, it's pretty much non-existant, because they will load up and not want to go very well at all. Make sure the main is right first. Once the main is correct, then if it bogs when you give it throttle see if it's a sputter or a smooth bog. Sputter should mean it's too rich, the smooth sort of waaaa sounding bog is usually lean. Change needle position accordingly.
Remind us what pipe this is please.
Post by brandonscoot on Oct 27, 2011 17:52:02 GMT -5
its the scrappy dog pipe. its packed with fmf power core packing, i was kinda thinking about putting a better silencer or something
Post by brandonscoot on Oct 27, 2011 17:52:40 GMT -5
and the jetting info is just what i needed, im going to try that soon
Post by jmkjr72 on Oct 27, 2011 18:15:00 GMT -5
loud is lean that is as long as you dont have a leak
Post by Fox on Oct 27, 2011 18:39:02 GMT -5
Can you adjust the clip on the needle? If so lowering it should help.
Post by brandonscoot on Oct 27, 2011 19:21:58 GMT -5
really? im gonna try that!
Post by Fox on Oct 27, 2011 19:43:12 GMT -5
Yeah, raising the needle position at WOT will let more fuel into the chamber. Lowering the clip raises the needle. I've seen guys put a tiny washer under the clip on carbs that have no clip adjustment. This is a 4T clip:
Post by brandonscoot on Oct 27, 2011 20:21:41 GMT -5
and i verified there is not a leak inbetween the filter and tip of exhaust. none.
im gonna try this clip action right now when i get off. ill see what happens.
