Post by jkeney on Apr 10, 2021 16:18:25 GMT -5
My yasuni r07 definitely needed a new braket fabbed up to fit, but I really think it was worth it.
Post by jkeney on Apr 10, 2021 16:20:08 GMT -5
Checkout my Roughhouse build thread. I made a bracket in CAD that can be cut with the online laser cutting service SendCutSend for about $29. It works well for my Yasuni R If mine were to break for any reason, I will def be trying your bracket.
Post by hippo008 on Apr 10, 2021 16:34:08 GMT -5
Off topic but I see your corsair power supply box there, we're you one of the lucky few that got an RTX 3080? On a 650W probably not, maybe a 3070?
Post by jkeney on Apr 10, 2021 16:40:18 GMT -5
Off topic but I see your corsair power supply box there, we're you one of the lucky few that got an RTX 3080? On a 650W probably not, maybe a 3070? hahaha no that was for my wifes pc. Ive got a 1000w evga in my rig. Im currently running a vega 64 and an i7 clocked to 4.3 ghz and 32 gigs of ram. Im waiting on parts availability to stabilize and ill be upgrading everything in my build, and donating this to my wifes build.
Post by hippo008 on Apr 10, 2021 16:51:46 GMT -5
My rig. I think it's the most unbalanced machine I've ever used. i9, 32Gb of DDR4, 2x 240mm radiators, noctua fans all the way around, 1000w EVGA power supply all in an mATX package......with a gtx770. I *would* have an RTX 3080 liquid cooled In there but they aren t avaliable! So I'm stuck with my circa 2012 Era card for now
Post by jkeney on Apr 10, 2021 22:06:27 GMT -5
Omg im so happy with how it looks.... I put the front fender back on and got those dangling sensor wires hidden, but didnt get a pic cause it got dark out. Now ive got to get that front wheel pulled off for paint and the other new tire.
Post by jkeney on Apr 11, 2021 13:36:08 GMT -5
Dropped the main jet from a 108 to a 106 to see if temps came up. Def more power and temps never went over 250. Going to drop down at least to a 105 and see what that does when I can actually ride it WOT on the road without getting a big ticket just for being out there.
Post by hippo008 on Apr 13, 2021 16:20:47 GMT -5
You did the gearup, how does that affect the ride? I'm thinking about getting some gears for the roughhouse.
Post by jkeney on Apr 13, 2021 22:12:29 GMT -5
You did the gearup, how does that affect the ride? I'm thinking about getting some gears for the roughhouse. Ive only ripped it on the road outside of my storage unit twice and was only in the throttle for like 5 seconds. From what i can tell it has not hurt acceleration one bit! I dont think I would have wanted to ride it with this setup on stock gears! Damn thing might have done a flip when I took off! Its got lots of acceleration and seems to be settling in around 9500 rpms but I cant say what over rev is going to be. I need to switch my clutch springs out to get a later engagement and I'll see what the belt travel is later.
Post by jkeney on Apr 15, 2021 15:16:25 GMT -5
200 mm NCY rotor and caliper bracket are out for delivery, and the Malossi brake pads get here tomorrow. I got the rim painted, tire mounted, and just for simplification I removed the guts from the speedo puck. Wont be needing it to do anything other than act as a spacer. I also ordered the NCY front forks today. Only thing left on the whole bike to upgrade is the rear shock at this point, and front caliper. I dont think ill be upgrading the caliper though. I just cant see how the NCY caliper is actually an improvement.
Post by jkeney on Apr 15, 2021 15:20:11 GMT -5
Ive got a really nice set of tire irons, but the front tire was a BITCH to get on... I've done so many scooter tires by this point, and this was the most stubborn one. My wife really got to me by saying "some jobs are better left to professionals"... I just couldnt walk away from it and pay someone to do it for the first time! She knew damn well what she was doing. Lol
Post by jkeney on Apr 15, 2021 17:11:02 GMT -5
Post by aeroxbud on Apr 15, 2021 18:11:27 GMT -5
That's got to help. 😁 Will you have to fit the caliper, before fitting the disc?
Post by jkeney on Apr 15, 2021 18:23:34 GMT -5
That's got to help. 😁 Will you have to fit the caliper, before fitting the disc? I havent tightend it up all the way yet, and still need to put lock tight on them. Im waiting to throw it all together when I get the fork legs in.
Post by repherence2 on Apr 15, 2021 19:32:25 GMT -5
With a big disc/rotor like that, you may have to fit up the rotor and caliper at the same time. That's how i had to do it on my 10" Chinarelli front wheel with a 200mm disc.
