raf12
2006 Yamaha bws owner
Post by raf12 on Apr 4, 2021 22:34:22 GMT -5
So I have a 2006 Yamaha bws 2 stroke whit a 50cc gianelli extra v2 and a cold air (high flow) pod filter and it runs well but would need a bigger jet so what size would be good and also what since are the jets like 6mm or 5mm thx:)
Post by jbjhillbilly on Apr 5, 2021 4:40:28 GMT -5
Leave the stock airbox on. Way, way easier to tune.
Pretty sure you need 5mm jets, but [mention]fugaziiv [/mention] would know what you need (he’s a vendor, and a good one).
Also, you should tune the CVT to take advantage of the pipe.
Post by aeroxbud on Apr 5, 2021 8:22:42 GMT -5
Welcome to the forum. You really need a pack of jets, not just one. To find what pack would be best. You need to see what size main jet you have as standard. You could Also measure it then, and see what type it is. The pod filter will just make it louder, and use more fuel. It won't increase the performance.
Post by geoffh on Apr 5, 2021 8:40:02 GMT -5
A picture of your carb would help,if it,s dellorto i, d plump for 6mm jets.
raf12
Post by raf12 on Apr 5, 2021 13:19:06 GMT -5
So I forgot to mention that I did tune my cvt it as a 107mm sport clutch whit a sport 107mm bell and 4.7g rollers I way around 120pounds and also I checked and my carburetor use a 6mm main jet at 80 82
Post by captincvmn on Apr 5, 2021 13:40:05 GMT -5
Why do you think you need a bigger jet? Overheating?
