Post by rocketbooster on May 6, 2021 14:31:19 GMT -5
HI I want to indroduce stuff that i do in my basement My main project is like in title mbk booster rocket. Rare scoot even in Europe. I have done few mods. Maybe i list things i done to it. Starting form the bottom: TEC racing crank with c4 bearing and vuitton seals Malossi sport ported, raised about 1,5mm then top deck was machined, squish 1mm timming 189 exhaust 128 transfers yasuni c16 pipe stage6 mk2 bigvalve polini cp 21 timming advanced 20* MHR overrange variator Piaggio 128mm pulley stock piaggio clutch stage6 wing cooler clutch bell gears for now stock 13:1 I will supply thread with pics off build, stay tuned. sorry for my bad english I trying my best. I hope u understand what I have to say.
Post by Lucass2T on May 6, 2021 14:38:25 GMT -5
Nice setup! MBK rocket is a Yamaha BW's Spy right? They weren't too common no, and always came in blue! Dunno the MBK liveries tho, probably the same as Yamaha. You must be from Belgium or France since you own a MBK scoot
Post by aeroxbud on May 6, 2021 15:58:44 GMT -5
That sounds a nice specification. Pictures please.
Post by rocketbooster on May 6, 2021 17:34:15 GMT -5
Post by Zino on May 6, 2021 18:24:08 GMT -5
Welcome to the forum You have one sharp looking scoot .
Post by aeroxbud on May 6, 2021 18:25:53 GMT -5
Very nice 👍 Is that a Peugeot caliper on there?
Post by rocketbooster on May 7, 2021 1:26:56 GMT -5
Yes, is so huge haha but pads don’t have full contact with rotor and I’m looking for solution. Already shave adapter but it isn’t enough. Also have a brand new set of oryginal body panels, white set was custom and i can’t mount head lamp and tail light with it. Short video how it runs youtu.be/qmSweg5H3HU
Post by yambw’s on May 7, 2021 6:16:12 GMT -5
Bike looks great! What rear shock/suspension is that?
Post by aeroxbud on May 7, 2021 6:38:03 GMT -5
I have the same caliper. Have not fitted it to the aerox yet. Might be easier to fit a bigger disc.
Post by rocketbooster on May 7, 2021 7:53:29 GMT -5
Bike looks great! What rear shock/suspension is that? Doppler same as front forks
Post by rocketbooster on May 7, 2021 8:03:47 GMT -5
I have the same caliper. Have not fitted it to the aerox yet. Might be easier to fit a bigger disc. For this exact wheel is hard to find rotor bigger then 190mm, stock is 180mm. After grinding adapter about 5/6mm, brake pad sticks out about 2/3mm behind rotor so not big deal I think. Most part have contact. I have thought that i can machne part of caliper which adheres to adapter.
Post by aeroxbud on May 7, 2021 10:21:27 GMT -5
That's a good plan. Plenty of extra material sticking out of the mounting holes.
Post by rocketbooster on May 7, 2021 14:53:02 GMT -5
I need to find machine shop with mill, all of my machining was done with belt sander haha, then sand paper on true flat surface. Of course engine was presure tested after.
Post by aeroxbud on May 8, 2021 14:14:55 GMT -5
Post by rocketbooster on May 9, 2021 4:08:13 GMT -5
I have rotor with 4 bolt design and like i said I look for it every where, only doppler has it but out of stock
