Post by aeroxbud on Jan 20, 2022 15:45:00 GMT -5
Yamaha doesn't make seals. So as long as you buy a good quality product, in the right size, be fine. A lot of places sell them as a kit with bearings. But any good bearing supplier will have them. Just measure them to see what size you need.
Post by rocketbooster on Jan 21, 2022 17:37:25 GMT -5
EasyParts.NL allredy told me what i need 😅
Post by fly on Jan 21, 2022 17:55:47 GMT -5
EasyParts.NL allredy told me what i need 😅 Gosh, a seal I need to replace on my Aerox front wheel looks just like that. I have some CR/SKF of the right size, but they don't have that triple lip. Or double lip with mud seal, as the case may be. When you get the seal, if there's mfg info on it I'd appreciate it.
Post by aeroxbud on Jan 22, 2022 4:30:01 GMT -5
EasyParts.NL allredy told me what i need 😅 Gosh, a seal I need to replace on my Aerox front wheel looks just like that. I have some CR/SKF of the right size, but they don't have that triple lip. Or double lip with mud seal, as the case may be. When you get the seal, if there's mfg info on it I'd appreciate it. It is probably the same. www.pedparts.co.uk/product/6414/front-wheel-bearing-seal-yamaha-aerox-bws-jogYamaha part number 93106-20001 looks like the Jog, BWS, and aerox use the same seal.
Post by fly on Jan 22, 2022 17:02:50 GMT -5
Cool, I'll grab one and see if that's it. I can remember my wheel spacer size vs the stock NA rims but it's wider, as I recall.
Thanks!
Post by rocketbooster on Jan 24, 2022 17:12:45 GMT -5
In next few days i will order unvisable valves for wheels and start asemble. Now i start preping body panels for fresh paint, also i have eye on coil on plug. Something like this:
Post by rocketbooster on Jan 25, 2022 10:49:17 GMT -5
Post by rocketbooster on Jan 31, 2022 15:57:53 GMT -5
3 from 9 stripped
Post by rocketbooster on Feb 5, 2022 9:02:07 GMT -5
New update Does it metter where is plus and ground?
Post by rocketbooster on Feb 13, 2022 10:57:16 GMT -5
After 1 month and 2 days after order, I finally receved package, it is time to do some work
